Removing lower window seal???
Mark300zx
1,459
8
Surrey/SW London
Just wondering if there is any special technique to getting the window rubber/seal off, it's the part that cleans all the rain off when you lower the window???
BBoy82
Dan the compressor man...
Oct 25, 2008
293
East Northants
Not sure to be honest on the fronts, but i replaced the rear drivers side one as my wife caught the very front bit as she got out, and bent it at 90deg.
The rear seal is just clipped onto the top edge of the doorskin. You push down on it to release the top edge, which then can be pryed forward and down.
Elsawin would be your best bet though.
BBoy82
Oct 25, 2008
293
East Northants
Wow. Really descriptive!!
Assembly overview
1 - Crystal glass
q Fitted on to the flange
2 - Door glass
q Removing → Chapter
q Adjustment → Chapter
3 - Door
4 - Outer glass guide
5 - Window glass hollow gasket
6 - Trim
7 - Star-head screw
8 - Spring nut
9 - Bolt:
q Tightening torque: 20 Nm.
10 - Window glass hollow gasket
11 - Door unit sub.-frame
q Removing and installing → Chapter
q The window riser forms part of the unit sub-frame
12 - Bolt:
q Tightening torque: 8 Nm.
13 - Electric window riser motor
q Is fixed to the rear part of the door unit sub-frame with the screw → Item
14 - Bolt:
15 - Hood
16 - Bolt:
Feb 26, 2009
5,275
Wolverhampton
Get the edge of the trim where the two doors meet, and twist it slightly so you can see down into it. You should see the hook in Phil's photo. Disengage that, then the rest of the trim will lift out vertically. The front doors come out as one piece, the backs are joined to the rear quarter rubber.
