Wow. Really descriptive!!
Assembly overview
1 - Crystal glass
q Fitted on to the flange
2 - Door glass
q Removing → Chapter
q Adjustment → Chapter
3 - Door
4 - Outer glass
guide
5 - Window glass hollow gasket
6 - Trim
7 - Star-head screw
8 - Spring nut
9 - Bolt:
q Tightening torque: 20 Nm.
10 - Window glass hollow gasket
11 - Door unit sub.-frame
q Removing and installing → Chapter
q The window riser forms part of the unit sub-frame
12 - Bolt:
q Tightening torque: 8 Nm.
13 - Electric window riser motor
q Is fixed to the rear part of the door unit sub-frame with the screw → Item
14 - Bolt:
15 - Hood
16 - Bolt:
