Rebuilding Engine (info)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
any updates on this one Danny.....whats happening now as you are sticking with your hybrid k03s and not going BT
or will you build this, for a strengthened engine anyway and put your k03s on....just in the case of you ever going BT
yeah im still doing it but in my own leisure...Getting all the service items 1st then i can save for the INA rods and pistons...
Once its done i can put it on to the hybrid....just need her to sort a car out...then its game on..
Which this soddy recession would end tho...pissing me off lol
Oct 31, 2006
870
Cambs
Have you found anywhere that does a valve spring compressor that fits the 1.8t head, seem to remember it's an od size?
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Righto...
As more and more parts are arriving..
How much would labour be to fit the following
Full Bottom end seals
Big End Bearings
Rods with pistons
Head gasket
Timing and Alternator Belt With usal Tensioner ect...
New Piston rings
And maybe for the cylinder head
New valves
New Full seals
New Springs?
As id be supplying all the parts everything needed for the job just need someone to fit...What price would i be looking at?
Oct 31, 2006
870
Cambs
I had my valves, springs, retainers, stem seals and guides fitted for £180 mates rates he said it would normally be double that.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
What happend to doing it all yourself?
I bet your looking a a fair few hours labour for that lot!
I come to the conslusion David is that il spending around £1300 on bits for the engine and i don't want it going Bang the first time i come on boost...
As id be kinda pissed wouldnt you agree..
Id be looking in to gettin a 2nd hand cylinder head and getting it sent off to be Skimmed & Ported and polished...
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Sounds a sensable option to me!
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah ..
Is the AUM Bottom end the same as the AQX bar the rods and pistons?
As im thinking to get the AUM sent off to be bored out to a 1.9 then il fit my Rods to that and buy some pistons with a 20mm pins ect....
jamiebennett81
Yeah ..
is it actually worth it for the turbo/power you will be using?
I thought the turbo was good for around 330bhp....which a standard 1.8T will run fine, so would be there be any point in doing it i.e. translating it into the "on the road" difference between standard and 1.9 bore
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Bttt for jamie Bennett
New big end bearings/shims = £4.56 +VAT each
New head gasket = £28.96 +VAT
New head bolts = £3.42 +VAT each
New cambelt = £21.40 +VAT
New water pump = £30.50 +VAT
New Oil Pump = £92.90 +VAT
New Rocker Gasket = £17.14 +VAT
New Throttle bodie gasket = £11.54 +VAT
New Oil sump Gasket = £14.74 +VAT (sealer)
New Timing Belt Tensioner = £41.00 +VAT
New Piston Ring set = £29.25 +VAT
jamiebennett81
gunna go and start reading this thread from scratch in preparation for my build in the next 12 months
good source of info mate
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
I thought i might aswell update my thread as i desided to do it my Self along with the Help of Ibiza alex and Cupramvr....
Anyway pics of how ive got on and were im up too..:
Now that My Big turbo conversion was all Done and running and producing good power for me...I was Next moving on to the bodywork But sadly a few days ago my water Pump Gave way...
So ive had to Put the Money else were in to the engine...I desided to Do a Full rebuild well as near as dam it..
What ever i could replace with the engine in situ from gasket to bearings ect..
So it sat for a few day while i pondered on what todo so i desided along with a few mates to pull it all apart and get it done..As it wouldn't get done by its self...
So i started by removing the Inlet manifold And Rocker cover then Drained all the coolant out which i had in it...
Then i got cracking on with the manifold on the IHI amazinly i don't have to take the turbo off or even downpipe so that makes faffing about alot less...
I know this might sound sad to people but as me doing this with mates i desided to box and lable everthing that i had taken off...Bit of organizing tbh:
Pics:
How it looked after the BT conversion that i had done:
Then:
I then Desided while it was in bits this would be my only and easiest chance to Smarten and Paint a few things..So i started with the Alternator to freshen up..Also painted brackets and Alt Tensioner to clean them up atleast:
my pots of which i have many off:
And current parts in order of which i took them off:
So while its in bits i desided to uprate my rods as running 1.5bar at the limiter is in rod bending terrioty.As you can see a massive difference between the OEM rod and my Scat ones:
I didn't get much done today due to it raining but tomorrow i want to get the :
* Oil Drained
* Remove Oil Sump
* Remove water Pump
* Remove Timing belt & Tensioner
Then once my Head Bolt Remover has arrived i can remove the 20v Cyclinder head and get it sent off to be full Rebuilt...Due to funds & time im gonna keep the OEM Valves but with New Springs and Guides ect...
While the pistons and Rods are Out im going to De-glaze the Bores with a 180 Grit hone then replace with new rings.Headgaskets,New Shims & gaskets...
Alot more pictures to follow...:
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Thanks John..
I spent another hour on it tonight after work...So i ended up getting the sump off which was really easy looking at it....
Then by my suprise i got the manifold of ''Without'' removing the Turbo,lines & downpipe and i done it with easy to...
So next for me is to remove the following:
* Remove Alternator Belt
* Remove crank shaft pully & Bi plate
* Remove Timing belt and Tension
Then Remove then Water Pump ;)
Just gotta meet up with john to borrow his Head Bolt Kit then i can get this 20v cyclinder head off and get on with the rebuild...
I got a few pictures as usal...
My Custom 3'' T.i.p which sounds immense:
Under Neath with the crank and rods showing(Covered up with a dust sheet)
Then gave the Bottom Sump a quick Lick of paint but i feel i need to treat my self to a baffle jobbie :D
Big Thanks to John & Alex for Helping me so far :D:happy:
