I thought i might aswell update my thread as i desided to do it my Self along with the
Help of
Ibiza alex and Cupramvr....
Anyway pics of how ive got on and were im up too..:
Now that My Big turbo conversion was all Done and running and producing good power for me...I was Next moving on to the bodywork But sadly a few days ago my water Pump Gave way...
So ive had to Put the Money else were in to the engine...I desided to Do a Full rebuild well as near as dam it..
What ever i could replace with the engine in situ from gasket to bearings ect..
So it sat for a few day while i pondered on what todo so i desided along with a few mates to pull it all apart and get it done..As it wouldn't get done by its self...
So i started by removing the Inlet manifold And Rocker cover then Drained all the coolant out which i had in it...
Then i got cracking on with the manifold on the IHI amazinly i don't have to take the turbo off or even downpipe so that makes faffing about alot less...
I know this might sound sad to people but as me doing this with mates i desided to box and lable everthing that i had taken off...Bit of organizing tbh:
Pics:
How it looked after the BT conversion that i had done:
Then:
I then Desided while it was in bits this would be my only and easiest chance to Smarten and Paint a few things..So i started with the Alternator to freshen up..Also painted brackets and Alt Tensioner to clean them up atleast:
my pots of which i have many off:
And current parts in order of which i took them off:
So while its in bits i desided to uprate my rods as running 1.5bar at the limiter is in rod bending terrioty.As you can see a massive difference between the OEM rod and my Scat ones:
I didn't get much done today due to it raining but tomorrow i want to get the :
* Oil Drained
* Remove Oil Sump
* Remove water Pump
* Remove Timing belt & Tensioner
Then once my Head Bolt Remover has arrived i can remove the 20v Cyclinder head and get it sent off to be full Rebuilt...Due to funds & time im gonna keep the OEM Valves but with New Springs and Guides ect...
While the pistons and Rods are Out im going to De-glaze the Bores with a 180 Grit hone then replace with new rings.Headgaskets,New Shims & gaskets...
Alot more pictures to follow...:
