Rear, upper strut brace
Equalizer
103
Poland
Hello.
I want to install rear, upper strut brace to my LCR, but I don't know for sure if brace, that I found will fit.
That is what I found and how it should be installed:
Is this a proper brace and proper way of installation? I'm little afraid, because if I will have to mount it like this, I will have trouble to get to my spare wheel.
nd-photo.nl
4,161
331
The Netherlands
youtube.com
Correctamundo!
This is the Whiteline 24mm if you are on a bit of a budget. It makes a massive difference, I think its the best mod for your suspension you can do. Makes the back of the car more predictable (you will feel better when it's going to slide).
I have a front 23mm ARB and Whiteline 24mm rear ARB. On FWD cars is best if the rear ARB is bigger than the front ARB.
Whiteline 24mm Rear ARB overview by ND-Photo.nl, on Flickr
ARB Link closeup by ND-Photo.nl, on Flickr
ARB Wheel link closeup by ND-Photo.nl, on Flickr
ARB through 18" Wheel by ND-Photo.nl, on Flickr
Equalizer
103
Poland
Wow, it's a little bit close to the ground :) Do you have any problems with a bumps in the road?
If you're saying, that it makes so big difference than I'll think about it. But tell me please if the rear ARB from Audi S3 will do the similar work?
Equalizer
103
Poland
Oh, you're right. I've forgotten, that they are 4WD.
But I see, that I would have to buy those "connectors" (I don't know how to name it in english):
What do you think about this set? Will it be good?
pol_pl_Stabilizatory-sportowe-Eibach-Anti-Roll-Kit-Seat-Leon-1M-11-99-08-05-21261_1.jpg
nd-photo.nl
4,161
331
The Netherlands
youtube.com
The Neuspeed or Eibach will be tighter. Mine allow some play, but the rose joints used by Eibach/Neuspeed allow far less play.
I have seen people modifying the Whiteline kit with Rose Joints (check eBay or Hardware shop).
Ash-Kennard
why are you reading this?
Jul 31, 2008
286
portsmouth
Don't bother with the rear strut brace. Keep your boot functional. Basically does nothing, but remove some chassis flex.
Get the rARB from Eibach. You won't regret it.
