I also did the fishing bit... hahhaha
Seems like if you tamper with the lights... as punishment you must fish.
I used a coat hanger wire with a huge ball of tape on the end.
This after having almost dis-assembled half the car.
With regards, to lights.
Here some folks do it with spray, others with film.
Try and get some paint for stained glass.
Its a perfect finish, clear, no running, and easily removable.
Problem with spray is that if you dont sand the lenses lightly (which make them unusable afterwards) is that it will most likely peel.
There are some sprays available on the ebay just for this effect... Id opt for that solution.
Good Luck there fellows.
xd-data-ii : Nice Job
