Rear Breaks Pads - Bad uneven wear, possibly binding?
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Hi All
Just had my rear tyres replaced and the guy fitting them asked me if i wanted to look at my rear breaks as when he took the wheel off he spotted the pads had bad uneven wear. :-o
The outer pad has lots of meat on it but then he showed me the inner pad which was just starting to touch metal of the pad :blink:
So thanked him for bringing it to my attention and said i would have a closer look at it myself later. As just forked out for new tyres :rolleyes:
Been researching what could be causing it to bind so bad, if that's what it is doing? From what i have read it could be pointing to the slider pins not moving freely, so needs cleaning out and re-greasing.
Could be alot of things i know but looking at the things i feel confident that i could attempt to fix myself. I have changed discs and pads before myself but if it comes to me having to strip down a calliper then i don't want to risk it, as its my breaks at the end of the day so quite important :D
Any suggestions what to check would be great as alot of the links in other threads are dead. Also what grease do you lot recommend to be used for the slider pins?
Cheers :)
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
It's not the pins mate it's the piston that's fecked you'll need to replace the calliper or try get a rebild kit, happened to me b4 my mot I just got a calliper out the scrapies least you no there all original parts.
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
aaa Sh*t, was hoping it was not the case, thinking about it i had a break service last year or year before on them as they were binding but it must be doing the same thing again so probably going to be new callipers as don't thing garages bother taking them apart just replace them.
Not sure i would want to get replacements from a scrappy as they will be quite old for my car and could just have the same problem again in a few years time? Would rather spend more and get them new so i dont have to deal with this problem again, as car would be replaced sooner before callipers had this problem again me thinks :p
What about new ones from ECP?
Pagid Caliper (Rear Left) Part No.: 133442190Pagid Caliper (Rear Left) Was £95.94
Now £71.82SEAT Leon 1.8 (2004)Brake Calipers hydraulically operate the brake pads to create the ... Learn more...
Actual cost: £107.82
In StockFREE delivery available*Next day delivery available (Order before 4pm Mon-Fri)PagidPagid Caliper (Rear Right) Part No.: 133442200Pagid Caliper (Rear Right) Was £95.94
In StockFREE delivery available*Next day delivery available (Order before 4pm Mon-Fri)PagidPagid Caliper (Rear Left) Part No.: 133442210Pagid Caliper (Rear Left) Was £110.40
Now £83.94SEAT Leon 1.8 (2004)Brake Calipers hydraulically operate the brake pads to create the ... Learn more...
Actual cost: £119.94
In StockFREE delivery available*Next day delivery available (Order before 4pm Mon-Fri)PagidPagid Caliper (Rear Right) Part No.: 133442220Pagid Caliper (Rear Right) Was £110.40
In StockFREE delivery available*Next day delivery available (Order before 4pm Mon-Fri)PagidPagid Caliper (Rear Left) Part No.: 133442810Pagid Caliper (Rear Left) Was £133.20
Now £102.00SEAT Leon 1.8 (2004)Brake Calipers hydraulically operate the brake pads to create the ... Learn more...
Actual cost: £138.00
In StockFREE delivery available*Next day delivery available (Order before 4pm Mon-Fri)PagidPagid Caliper (Rear Right) Part No.: 133442820Pagid Caliper (Rear Right) Was £133.20
In StockFREE delivery available*Next day delivery available (Order before 4pm Mon-Fri)PagidBosch Caliper (Rear Left) Part No.: 133442217Bosch Caliper (Rear Left) Was £110.40
Actual cost: £119.88
In StockFREE delivery available* BoschBosch Caliper (Rear Right) Part No.: 133442227Bosch Caliper (Rear Right) Was £110.40
In StockFREE delivery available*Next day delivery available (Order before 4pm Mon-Fri) BoschBosch Caliper (Rear Left) Part No.: 133442817Bosch Caliper (Rear Left) Was £133.20
Actual cost: £137.94
In StockFREE delivery available*BoschBosch Caliper (Rear Right) Part No.: 133442827Bosch Caliper (Rear Right) Was £133.20
Bigjohn84
May 5, 2015
2,330
I've had mine on nearly a year now and it's still perfect, it's ok if u have the money but if u haven't then scrapies it is, plus there all genuine seat parts unlike the other that none seat dealers sell.
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Well my bank is saying no but my credit card is saying yes :rolleyes:
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Just done it myself mate took about 15 min
Did it myself. Took less than an hour to complete.
Lost hardly any brake fluid so was easy to bleed back up.
Your both tempting me now... to do it myself [B)]
Is there any guides? Did you not have to bleed all the break fluid out?
LOL went to Seat dealer to have a laugh, just to see how much new callipers cost, as i needed a replacement bulb for rear break light and as you can probably guess, i only walked out with a replacement bulb :wtf: £170..... EACH :-o
chris2r
53
Sheffield
Just need someone to step on the brake pedal while you bleed them.
You can change all the fluid if you want but can be difficult to bleed if air gets into the abs pump.
Think I lost 200ml at most and just topped up.
Few guides on here but if you can move a spanner then it's pretty easy.
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Mate it's really just common sense, wheel off,two nuts back of calliper, caliper of, clamp hose, disconnect hose and hand break cable, done. Put parts back together then bleed brakes
Hear a MK2 thread how to do it but all the same mate.
http://www.seatcupra.net/forums/showthread.php?t=225698
Nice one cheers to you both, have got a garage to take a look at it today who will have a closer look and confirm what is at fault without charge :) If its just needs a break service (Clean up / re-grease) i will get them to do it but if it needs new discs/pads and callipers i will give it ago myself. :happy:
Thanks for the link to the guide but it only looks to show how to change pads and discs not the calliper but still good to refresh my memory on how i did it last time. Will search the net for guides on changing callipers :).
Bigjohn84
May 5, 2015
2,330
Instead of taking the pins out just take the two bolts out and the caliper will come of then just undo everything like I said, it's easy mate.
Also all you need to do is change that part so you can follow part guide lol
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Thanks for all the help! Took it to local garage who offer a free break check, they confirmed that callipers are ok and greased up my slider pins as one was not moving, but said my discs and pads need changing...:rolleyes: Bit cheeky but just thanked them and said i will think about it as did not want to pay £180.
So ordered the parts plus windback tool and did it myself today..... WINNER :whistle:
Rich.T
1,609
932
Morning all.
Ive got a MK1 Cupra r with the red callipers fitted.
Are they Brembos all round or just on the front?
Did a couple of miles yesterday and noticed a burning smell when id stopped. The osr caliper was hot and the source of the smell.
To be honest, im not sure if id left the hand brake on 1 click so will be driving it again before i start buying parts.
Obviously the car has been sat around a fair bit over the last few weeks due to the lockdown and maybe lack of use has caused this problem to occur sooner rather than later. Only had the car a couple of months and the rear pads n discs look new.
Cheers all.
Rich
Brimfull
1,385
418
Wrexham
Morning all.
Cheers all.
Rich
Classic symptoms of sticking caliper, may have been caused by sitting around for long period. Keep an eye on it to see if it frees its self up.
If it doesnt have alook at a&a core on Facebook and ebay they refurbish calipers and powder coat them. Cost me about £250 for four calipers to be refurbished and powder coated on my mk2 fr
Sent from my SM-G960F using Tapatalk
Reactions: Rich.T
Rich.T
1,609
932
Thanks for your reply.
I think you are right. Going to try and fix it sooner rather than later. Once the world starts turning again, ive got some decent mileage to do so the car needs to be ready to go.
Thanks Rich
