Thanks XE, will give it a go in the morning. Just need to find something to use as removal keys!!
My rattle is fixed wooo! was the jacking point prob, had stones in the under tray too
After sending my car to the dealer 4 times for a rattle in behind the centre console, sounded like it was behind the climate control it still wasn't fixed! I decided after looking through this thread to give it a go myself, after 30mins, including removing stereo and climate control unit I had found and sorted the rattle.
Makes you wonder what the dealer is acutally doing, from what I can see their idea of fixing it has been to cover everything in a layer of silcone grease as anything I touched behind the stereo has been plastered in it
Thanks for all the help and pictures in this thread it was invaluable , especially Carnivor you photos proved really useful
Well ive done it at last,
I've found the rattle, been able to make it rattle, and stopped it from rattling,
This is the problem,
See the little felt square between the vents, hardly a good contact, but thats not all, i found if i put a finger into the right vent and tap down, i can get a "click" so.... i made a bigger wedge where the felt square is,
made it out of strips of plastic taped together, about 5/7mm thick in all, wedged it into the gap between the felt and air ducting,
this presses the ducting down harder onto the foam join at the bottom (see top pic, it even looks looser on the right hand side).
Not a rattle since!!
Now i can sleep well at night
