Radio wont switch off, battery goes flat :-(
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
I eventually got mine to stay of by jumpering a couple of pins on the main board
Basically the micro switch from the tape player connects through those two terminals. Anyway after soldering them I never got the problem again.
joca_kg_serbia
Does anyone have some more ideas :(? I tried everything, and the console is still stay on all the time...When I press "tape" button, the casette player is not working,is that normal?
joca_kg_serbia
I've tried it both ways .. I wonder how unresponsive "tape" button is,probably the problem is the entire HU
yellonvi-R
4,331
birmingham
Well mine was doing this turning itself on and the volume button was dodgy, so i removed the face tookit in my house got the wd40 out sprayed the on/off volume knob not loads just abit, and swivelled the knob around!! This worked plugged it back in all good now!
*note* wd40 can melt the rubber coating of your fascia so place a rag all the way around the knob so you dont get wd40 all over the place!
draganp
Hello guys.
I have the same problem with the radio. It turns itself when the car is loocked...any idea?
draganp
What can work is just turning the stereo off before you turn the car off.
I turn the stereo off, turn car off, lock car...go home, when I'm back I can see that the stereo in my car is turned..it turns itself on
two years ago I had a problem, I couldnt turn on the radio, and after few days it worked, it was fixed by itself..i didn't fix it by myself....
Now I have a problem the stereo turns itself on...
Btw, I wrote in my profile that I drive vw passat...my friend drives ibiza mk2 99-02 with this problem
draganp
I read few posts about leaving a tape inside stereo. If I put a tape inside, then If I want to listen radio I need to pull back tape by pressing both button for fw/rw.
If I jumper two pins then I can only "listen" the tape, I can turn to radio?
Tucker157
1,066
Falkirk/Central Scotland
Put a tape in, most likely to fix it! Then push the radio button or cd button to listen to what you like... A tape lives in mine, never moved in 5 years!
Sent from my iPad using Tapatalk HD
draganp
At this ibiza the radio looks the same as attached photo (link). When I insert a tape, on display I can see text TAPE, but I havent radio button!
I havent 15 posts and I cant posta links..so please copy/paste this link
imageshack.us/scaled/landing/162/ibiza022ky0.jpg
Tucker157
1,066
Yours is the same as every other Ibiza mk3cupra!!! The round bunch of 4 buttons opposite side to the volume control.... One is RDS (RADIO) one is BAND ( ALSO RADIO!!) one is CD one is TAPE.
So you have 2 buttons for the radio!!!!
draganp
That 4 buttons are RDS1, RDS2, FM1 and FM2...if I press some of them during the tape is inside..nothing happens.
it looks like this
tweakers.net/ext/f/TXIswBVYuY4U6T9RVDb5ndx4/full.jpg
SystemPorche
well mine did it in seconds of turning off, so im sure its fixed it :)
Tucker157
1,066
Hmmmm... I stand corrected!! UK cupra's are as I stated previously. I have a tape with wire for playing MP3 players on it. Wire hidden in the dash.. Fixes the random turn on and gives me an auxiliary input.
It would appear its not as simple for you... If you leave a tape in does it fix your issue?
The reason it works with a tape it the tiny switch on the pcb board is poo and thinks a tape gets inserted and swiches on the stereo....leaving a tape in stops this..
try joining the two pins, may be your only option... It can always be undone... If it results in you stuck in tape mode the try removing the switch from the board... Who uses tapes anyway!!!!
