F2 Stu said:
This is a responce from a couple of questions I had
Hi, the manifold is designed to fit the ABF engine and thus has much less movement than a stock mainfold and has correctly sized ports to fit flusher and tighter at both ends. Stainless steel is 20% thinner than mild steel and much more so than cast iron. It therefore has much more flexibility. It works very well with std engine mounts. The product comes with a 12 month warranty unless damaged due to being incorrectly fitted by someone other than TSR. We hosted the Somerset and Dorset VW GTI Rolling Road Day last Saturday and everyone loved the manifold. The best comment I heard was that 'it's like sex and chocolate combined'. I think that says it all.
PMSL. What a load of crap.
"the manifold is designed to fit the ABF engine and thus has much less movement than a stock mainfold" - makes no sense
"Stainless steel is 20% thinner than mild steel and much more so than cast iron. It therefore has much more flexibility" - wall thickness is not the only thing to affect flexibility - you could make it out of plastic 5X the wall thickness of mild steel and it would be more flexible....the material also counts and as far as I remember, SS is less flexible than mild steel (any engineers like to comment ?)
But if they have checked it out with std mounts them fine....depends on condition of std mounts I would say.
The most concerning thing is they have provided no dyno-backed performance figs.....if it was that good wouldn't they be showing them off ????
But it looks nice.
Rob
