check the part numbers on them both mate if they are the same there shouldnt be a problem as the ecu should control the fueling id have thought, check the fuel pressure regulator on the rail too as it could be another variable
ahhh right didnt realise thats what you wanted em for i thought you just needed replacements and had a set of those bits knockin around lol, either way alpines right youd just be dumping more fuel into the same amount of air really so possibly a wider throttle body.. then the ecu should give the right fueling to match the air going in? :S
already have a pipercross panel filter and cold air feed i thought this might be enough air , possibly not though anyone know if a 6n 1.3 polo throttle body would fit ?
