Purple Leon Cupra R
Status
Not open for further replies.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
i made a new MAF pipe using some 80mm pipe 79mm internal diameter, the standard is 80mm too but inernal diameter is about 70 mm, i know its only a few mm difference but it all helps with flow.
cut and rounded to suit new pipe
hole cut in pipe to put MAF into
Both parts stuck together
Mounted in the bay
no comments anymore ????
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
if u have increased the maf tube diameter and removed the mesh surely everythings messed up now , scaling , A/F ratio etc
just thinking out loud
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
so if im putting more air in then this means i can run a whooshy dv
lol
NeilC
Has left the fold...
Mar 23, 2004
336
somewhere else
Oops, sorry was looking at the wrong bit (you've too many shiney parts lol)
I do think it'l make your maf readings go a bit pear shaped tho as i thought it assumes a certain dia pipe.
Check your knock values. I thought bigger maf would equal the car thinking there was less load so it'l increase timing.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
stoneyfordNI said:
have u had the car tested with an exhaust mounted A/F meter , u could be running lean ,
no, not yet, but its all getting ready for when its custom coded,
but just thinking about it the throttle will only let in as much air as it wants/ needs ? no?
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
stoneyfordNI said:
yes but that is controlled id say by the MAF and MAP sensors and ur MAF is not seeing all the air
but by changing the standard air box to a twister filter say this flows more air than standard, like what im doing?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
but the MAF knows that so much much air at so much velocity equals certain fuel , u have increased the diameter of the maf housing so u have more air at probabably a faster velocity which the MAF cant see
i think or am i confused
matt_s
4 8 15 16 23 42
Dec 23, 2004
654
19
You've got 30% more area for the air to go down. There is no way there is 30% more air going into the engine so it has to be going slower.
So you have a bit more air going slower, so the ECU sees it as less air than there is so it underfuels.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
the saturday before trax i fitted a HID kit , didnt take long atall, must say they are amazing and i wouldnt want a car without them now.
I also bought a neuspeed dipstick cap and power steering cap from the lads on the awesome stand, look top IMO
NeilC
Mar 23, 2004
336
somewhere else
Where did you hide the passenger side ballast? I was going to put mine on the side of the battery but atm ive just tucked it into the cloth surround on the bat. As you dont have the battery in the front you must have thought of somewhere better?
I changed the sidelights for led's too as the original ones looked far too yellow in comparison.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
used the bracket and mounte it just infront of the washer bottle, other side is mounted on the inside of the wing, they have to be in free air not enclosed btw as they get hot.
i hae angel eyes that came with blue bulbs that look white when on, much better than yellow
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
finally did the boot install not finidshed yet, will keep pics coming
(take no notice of the date lol not my camera, itwas taken sat nite)
Ibiza Cupra
well i gotta admit you have the most "complete" car i've seen on SCN, absolutely gorgeous!!!!!! Wot are the subs???
Status
