Project Bi-xenon : Adding bi-xenon projectors to standard headlights-Mission Complete
Sinan
Toronegra!
Dec 1, 2009
282
Turkey - Izmir
www.vagturk.net
will definately do, we had a local Seat meeting today at Izmir/Turkey which I organized, we had 2 DSLR cameras, one owner had to leave too early, other one fall to ground with tripod, result = dead lens which worth £450. So that I couldn't take detailed ones with pro cameras, but had semi-pro compact camera, took some pics with them, waiting for my friend to send me the pics :) We were 18 cars together :)
adambolus
1,200
11
Ripley, Derbyshire
They look great there pal.
And did you have to take the bumper to remove the lights or can it stay on?
And I don't know why all ibizas aren't fitted with the black bits inside them
Sinan
Toronegra!
Dec 1, 2009
282
Turkey - Izmir
www.vagturk.net
*must* remove the bumper to remove headlights. There are 4 screw-like things on top of grill, 1 or 2 in.. erm.. dictionary says "fender", I mean the place which wheel is in. Turn the steering wheel left or right to reach them :) very easy job to do ;)
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,304
7
Desborough
Looks fantastic mate. So your setup is exactly like the xenon option now? So indicators on the inside closest to grill and low and high beam on the projector and running lights on the outside where the indicators used to be?
Sinan
Toronegra!
Dec 1, 2009
282
Turkey - Izmir
www.vagturk.net
thanks! :)
for indicator nope. Indicators stay where they were, like standard headlights. I didn't swap them with the inside ones (which close to grill), afraid of lack of visibility, it could be dangerous at night, when xenons are on. So, the small lamps (the ones on top of reflectors, parking lights) and H7 led (inside one) connected parallel, they work as daylight. low and high beam on the projector as you said. :) will post detailed pics soon to make things clear. ;)
Sinan
Toronegra!
Dec 1, 2009
282
Turkey - Izmir
www.vagturk.net
New pic, no main/full beam pic yet though :(
Sinan
Toronegra!
Dec 1, 2009
282
Turkey - Izmir
www.vagturk.net
Projectors need to be adjusted more precisely.
Bonus:
I am after H7 led AMBER bulbs. Have any of you seen such product? I've found one, but the price was too high for it, so looking for alternatives.
ntemis21
107
Greece
i want to ask
what type of projector did you fitted???? and the lens diameter if you remember.
is it a mini projector like mini morimoto or is it like fxr so we have to drill the headlight to fit it??
did you have can bus or not???
Sinan
Toronegra!
Dec 1, 2009
282
Turkey - Izmir
www.vagturk.net
i want to ask
New Valeo bi-xenon projector has been used, same as Range Rover Sport, Bocanegra, etc.
Unfortunately I don't know the diameter :( some dig on Google would help, perhaps.
Reflector has been drilled. Also, covers behind the headlamp had some work on it. Length of the projector caused the cover job.
My car had H4 system, so not a Style pack one, therefore I guess ECU is fooler than Style :rolleyes: I had no issue with CAN-BUS, even I used OEM ballasts (Koito) which has nothing to solve the bulb failure lamp when used on CAN-BUS systems.
