funny that cause a car standing over night that's freezing can go straight on the rolling road and produce more power th an a car that's been drivin for hours and is red hot. Meaning the cooler the engine the better the power.
Disagree with that too. Any extra power in that case would come from the fact that the turbo, intake manifold,intercooler etc etc are all stone cold so you have less heatsoak and hence a cooler and more dense charge.
If the engine is cold, then so is the oil. That's going to increase drag and friction on nearly every moving part of the engine. Then you have the higher thermal losses to the coolant and cold cylinder walls. Both of those would be losing you power over the same engine that's up to the proper temp.
Also what dyno operator was it that did a run on a freezing cold car without warming it up first? Certainly wouldn't be letting someone who did that anywhere near my motor!
