Foz550
Hi everyone, I am after a bit of advice!
Am having big issues with my leon FR TDI, it keeps intermittently losing power (feels like the turbo goes) which if I turn the engine on and off again stops the problem and all is well again.
VAG said it was the fuel pump relay, so had that changed & still same issue & I have now had the fuel pump changed as well and I still seem to be losing power intermittently.
When I had the fuel pump changed my mechanic did a lot of VAG tests etc & it came up with the following code/problem:
17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
P1549 - 35-10 - - - Intermittent
Anyone got any ideas on what my problem could be? Is it likely to be this N75 valve?
Ive also had the following code come up a few times, do you guys think I need to change the fan system?
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Thanks in advance!?
Dave
Thanks in advance!?
Dave
