polybush top mounts anybody had experience
B47t0n
162
Ive just been looking at some polybush top mounts I read there a straight swap for standard and also give you a 10mm drop has anybody had any experience with these ?
Thank you
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
14
Lincoln
Go for solid top mounts. I've got KW top mounts fitted but you can buy silver line solid mounts off eBay. It allows more adjustability in set up. I've go 2 deg of neg camber on mine and it works very well.
mill5y
190
sheffield
I'v got powerflex top mounts, along with my joms... Been fine.. not over hard or teeth chatteringly vibrations.. dunno if they any lower cos my coils are wound down ;)
milner575
241
hereford
I've got powerflex top mounts on the way. Don't think they lower it at all. Will let you know when they finally arrive. Been a week already :(
B47t0n
162
That's good to hear then so guessing there a straight fit with no need to change top caps or anything reason i ask 1 of the mk4 boys on there forum said you needed polo top caps
MooRzy
245
Manchester
The psi tuning ones are a little bit lower, I've used modified top caps, but they are a bit too shallow. Good mounts though, much better than the polo top mounts, as they actually fit inside the torrent properly.
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
Powerflex don;t advertise a 10mm drop so don't know where people are getting that from?
I think the OP means Polybush the company who do advertise a 10mm drop. I was swayed away from them by Awesome GTI as apparently they had numerous complaints of knocking and such after fitting them so stopped supplying them.
Others may have had good experiences with them though so worth checking people's reviews!
285cupra-matty
488
Harlow
I have the poly bush ones (red bushes) and can confirm they lower the ride height by 10mm. As I had the spas 30/30 shocks and spring kit and the back always sat lower now the car sits level. They also are straight swap just pull old ones off put new ones on. I would advise ALOT of cooper grease to as I only put a thin smear on and they creaked like mad so covered them and now fine, ride comfort was slightly lost but then if your fitting these your probably not to bothered about that.
john_tdi
mmm 385lbft
Feb 21, 2007
687
s wales
my octavia dropped about 5mm on them (polybush). which is basically the same car.
I would agree with plastering them with grease as they are noisy otherwise. I re-greased mine a few months ago and already they are starting to make a noise again. Also they need to be fitted with polo top caps. Mk4 caps stick up too much and do bugger all.
From what I've read, polybush have made a hybrid of the polo bush and mk4 bush. As alot of people have been fitting polo bushes and audi 80 bushes to do the same thing for years. I'm not sure if I would bother again and the build quality isn't great. Plus the centre hole on mine has enlarged.
polybush vs brand new oem:
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
They would say that, Because they don't sell them. Did they try and sell you the powerflex ones instead ?
They used to stock them and stopped due to lack of interest/complaints. I was getting top mounts anyway and ended up going for Powerflex as I've not read anything bad about them yet.
