sounds like you were very lucky indeed, soaked intake and filter and no damage.
in hindsight id say if there is worry about water ingress then turning it over to see if it works is not the best approach.
Im no mechanic, but id say at the least you would need to do something like remove spark plugs, drain, and then turn over with sparks plugs removed to clear water?
anyway glad its all ok.
