Pink Brembo`s
ArosaRacer
Wee man returns in a fL mk2 cupra
Aug 28, 2005
2,299
18
44
Bayview, Kent
just did mine today used some wet and dry paper gave them 4 coats of clear now they look new only took me an hour as well
dont know if it will work with burn't ones
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
did you take a piccy of them before? mine are quite bad
also, what lac did you use?
....they look mint btw
ArosaRacer
Aug 28, 2005
2,299
18
44
Bayview, Kent
Yep took the pads out cleaned and degreased masked everything up and clear coated them, left them to bake in the sun !
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
Ok, sounds pretty simple, apart from the taking the pads out bit
I've never touched the brakes before so i'm a little nervous but might give it a go
So a dummies guide goes like this?
1) Losen nuts
2) jack up front of car
3) take off wheel(s)
4) ?? take out pads ?? (any tutorials on this or instructions?)
5) Degrease and clean
*EDIT: carefully remove flakes and Use P1200 wet and dry paper to prep surface
6) mask the whole area
7) spray with Hycote clear Lacquer
8) bake in sun
9) put pads back in etc...
ArosaRacer
Aug 28, 2005
2,299
18
44
Bayview, Kent
thats the way i did it, use Axle stands as well its better than just using a jack, i used standard clear coat and then left to dry
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
How long did you give it to dry? Normal lacquer takes 24 hours before it's completely dry, so did you leave it that long?
ArosaRacer
Aug 28, 2005
2,299
18
44
Bayview, Kent
nope couple of hours put the wheels on then left it till this morning drove to work and its sat there ever since ,
RobM
Sep 27, 2006
4,982
Southampton
Excellent. I suppose leaving it overnight does the trick really.
Might give this a go when I get the chance :)
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
Was yours as bad as this?
I knew they were bad but they look even worse with a big picture :(
Do you reckon they will come up ok ?
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
I'm still in the process of trying to find a company who is willing to professionally refub' my Brembos. I want a slight colour change too when I get it done but not many people are willing to do it for me :(
If you find a good place mate post up the details as im after getting mine refurbed as the fronts are falcking and the backs are fooooked so was thinking of going Yellow!
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
ok i've ordered the clear coat stuff
Got 2 can for £6, Dont get it off ebay its way expensive with postage, think i got it from 4wheels ?? (cant remember)
anyway, I need to get the p1200 wet and dry ( i assume halfords or b&q sell this) ?
and i need to get some degreaser, this is where i need some help, which stuff do i get and where do i get it from?
I'm hoping to do a tutorial on this for us novices
Mark
RobM
Sep 27, 2006
4,982
Southampton
Halfords sell plenty of de-greaser products. 'Gunk' is quite good, but there are others. Usually in the car cleaning section.
