Just a small update, ordered a new prodcut called WOT Box. Basically its no lif shiftiing and 2 step launch control.
Basically this allows you to change the gear without lifting the throttle, which helps put less strain on the box due to the ignition being cut for a short time when your at WOT on gear change thus the engine producing no torque allowing the syncros to mesh easier. Which also help keep on boost between gears.
The 2-Step Launch Control modulates the ignition by dropping power to individual ignition coils to hold the RPM you want to launch at. The turbo will spool up while you do this. You can use this feature for a more consistent and more powerful launch in boost.
