Mint day. Got up, went to stealers for oil (gold synta 5W40 for future ref), went to halfrauds for antifreeze (pink stuff). Went home. Called Saul "get yer ass over here". Wired up rad fans, installed ECU, added 7.5L oil to sump tank. Watched Turkish GP Qualli. Saul arrives. Plugs out, spin engine over on battery till oil lines primed and oil coming out of sender hole on back of head. Fit plugs, check coolant.
Right then, moment of truth. Turn key. Fires immediately
first time. Result. Warm it up, loads of steam coming out of exhaust from water that must still be in there from when it blew up. Bits of engine coming out also, valve seat, bit of piston......Runs fine, bit rich perhaps but to be expected from Dyno map. Warm it up fully and turn off. 2 stubby beers for the lads
Let it cool down.
When cool, start again and let warm up. Saul craps himself as engine 'coughs' some fuel out and bangs on startup LOL. Lot less steam this time so exhaust dry now. Run up till rad fans kick in - damn good fans, (Spal) shift a lot of air.
Job done. Try and get it in this week for 'engine in car' map to be installed and will need some RR time to tweak for more power expected than last engine.
To be continued.....(cheers to Saul again for
help, he has some vid that may be coming up later)
Ave it
Rob
