Parcel Shelf Speakers
Teasy
451
Middlesbrough
6x9's ???
I was thinking about wiring 2 new powerful....ish speakers into the standard speakers if it's not too much chew (onto the parcel shelf; the door type speakers not the box style)
2slim
I fitted a pair of 8" Kinetic (360w) speakers and a Alpine amp (220w) to my parcel shelf. (£200 in total) Sounds great, I can feel the vibes in the back of my seat :D:D:funk::funk:
The wiring has since been tidied up and the subs have been removed - need the boot space!
The parcel shelf is re-inforced with several strips of metal as I found out when I drilled / cut out.
PlatinumR
Arrived and lovin it!!
Jul 23, 2004
253
Shoreham-by-Sea
does that not just say steal me please??????
wouldn't you be better not advertising your ice by having some sort of stealth shelf??
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
Wot he said.
And the standard parcel shelf isn't designed to support that kinda weight - as soon as you crank it it will start vibrating.
In fact you're better off getting some really good components in the front and amping them - it's where the driver tends to sit. I don't really give a monkeys about the back seat passengers...
Jessiecar
I've put some good front and rear speakers in and it sounds great.
Also got 6x9's but they are hidden :)
2slim
Already done the doors :funk::funk:
swellcupra
hi everybody just bought a cupra FR 05 plate and need a bit of advice !
The system what ive got now has good bass and is pretty loud but want a new head unit would that effect the quailty also was finking bowt 6*9s on the parcel shelf would i need a amp ?
Jessiecar
Depends how powerful your head unit is.
You'd probably be better using an amp for the 6x9's but if you've got a powerful headunit they may sound ok running off that.
Mine are running of mine until I can open the boot and sort a install out :)
swellcupra
ive got the orginal head unit in now is it worth getting 1 . i had a 1.4 leon and messed around wit the system and it was crap just dont wanna do the same was finkin of a sony head unit 4*52 watt ! also if i got a new head unit could i get the silver spacers like the dash
swellcupra
hiya mate couldnt give me a bit of advice bowt fings menthioned above ta
OFI
350
Salisbury
bowt fings?
Anyway... I would think any modern HU would cope well enough as long as you stay away from the bottom of the range stuff. Plenty have 4x 50w or more these days.
6x9s will want a bit more amplification otherwise they will sound a bit weak.
Can't fault my Infinity 6x9s (in my other car) :) don't go for Sony XPLOD or JBL etc.. they're crap.
Myself, there is no way i'm cutting into my cupra to fit speakers which aren't going to be much better than the standard fit, the standard components are amazing, even the bass is pretty good although perhaps lacking a bit of you fancy yourself as a 'cruiser' :D
moley3000
I got an alpine system, head unit 4x60. All four doors have new speakers, the sub in and thinking about 6x9's but it may mess up the phase proccesor timings, cus more than 4 speakers is a waste of time, so i've been told, what do you guys think, i just want the best sound and the loudest.
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
4x60 watt is max power - you're looking at an RMS that is far more likely to be around 15 watts per channel. If you want loud you need an amp. I can't understand replacing all the speakers and HU without doing an amp - you're not using that equipment to anything like it's potential.
And I would probably give the 6x9s a miss. They might add volume but they won't add SQ if that's your aim.
swellcupra
mite just put new head unit in and keep the spekaers as u say they are top notch for standard one's ! would putting 6*9s on the parcel shelf create more volume then ? can u get the silver side plates for the dash
