Pancake pipe,what's it do?
strugers1
i went from the allard pancake pipe replacement and did not notice any losses at all!!!anyway interesting result on the water flow rate thingy:)
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Didn't you like the allards pancake pipe?
I didnt have an allards pancake.
I had the SFS one and it was good but had design flaws so I sent it back with info on what they need to change. I then moved to a 1.8T pancake pipe which is what I have now and that works really well. Hopefully this new round pipe will work just as well and this would mean there are no restrictions left in the system.
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
So does the 1.8T go straight on? Mine is buggered and I can't deciede what to do, replace it with stock or use a 3rd party supplier. I guess the 1.8T version will be easy and quite cheap.
Is the one you have from the AUQ, ARY engine?
strugers1
we have the cupra engine auq i believe the 180 bhp models:)
noticed a big sound difference as i have this set up too lol before i confuse the situation
brad1
To fit it properly, you will need a sfs turbo outlet pipe as these are 50mm diameter and the pancake inlet in 50mm and the outlet is a 60mm ;)
You get the idea, the standard red pipe wont fit over ;)
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Aaaah, thanks for that :)
Is that the stock ARL pancake pipe on the left?
I don't suppose you want to sell me your spare do you ;)
brad1
The standard pancake off my 110 is on the right, that is the 1.8t pancake pipe on the left, the stock 150 looks completely different and has them crappy connectors. Tho ill be selling this pancake pipe very soon as i have a more free flowing one coming ;)
strugers1
one on the left is the 1.8t one that myself and jonjay have also:)
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Chris I will be selling mine soon if it all goes well with this new one I bought.
trebormint
333
Swindon
Not sure if I've got hold of a different pancake pipe (but it looks the same as yours), but the turbo end is 54mm. Will the SFS pipe struggle to fit over this?
brad1
This pancake is the 1.8t one, it's completely different to the ones found on a diesel, the turbo end where the sfs pipe goes over is a 50mm diameter and the sfs pipe is a 50mm diameter, giving tight fitment ;) the other end of the pancake pipe is 60mm. Hope this clears up any confusion :)
trebormint
333
Swindon
:think: I think you saying 50mm I/D and I'm saying 54mm O/D! :rolleyes:
I've got a pancake from an Audi 1.8T (like the one on the left).
Vaughny
123
Gravesend, Kent
Sorry to resurrect an old thread, but better that than starting a new one.
If you get a FMIC does this do away with the pancake pipe? And if not, jonjay - what pipe did you get?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
It depends on what style of FMIC you use, inlet and outlet at either end will do away with it but a twinpass will keep it.
