P0136 Fault Code
Dec 10, 2021
Hello Folks. I've had my 2016 FR 2.0d since new and had absolutely no issues with it until recently. EML came on so I scanned it and got p0136 fault code. I bought a new sensor and changed the old one out. After starting the car I got P0036 and P0136. Swapped the old one back in and P0036 has disappeared. Still left with P0136 though. Anyone any ideas before I head into a garage with it. Cheers in advance
Walone
1,695
501
Near Heathrow
What sensor did you replace? Seems to me that you replaced the wrong sensor maybe.
Walone
1,695
501
Near Heathrow
The only thing I can think of is that the P0136 code is there because of a wiring fault and that the new sensor you fitted may be faulty thus giving the P0036 code, just a thought though.
SteveGSXR600K1
596
198
Do you have any VAG independent specialists near you? Have a go yourself, but I'd just take it to them. I've read too many posts of people trying to self-diagnose issues, spend a fortune on parts and get nowhere.
Reactions: Woody_72
Dec 10, 2021
Thanks I dont think there are any locally unfortunately. Im on leave tomorrow. If I can't find anything that sticks out I'll see if I can get it into a garage somewhere
Reactions: SteveGSXR600K1
jt20vt
190
46
As said before the fault code relates to a malfunction in the circuit. You could check the wiring for continuety on the sensor if you feel up to the job. Did you use genuine replacement sensor?
Dec 10, 2021
Yeah it's a genuine sensor. I can check the wiring for continuity, I might get under for a look again tomorrow. I assume that bank 1 sensor 2 is the one further down the pipe next to bulkhead?
jt20vt
190
46
Yep should be. Check the connectors incase of dirty contacts.
