Overheating TDI
muddyboots
Still hanging around
Oct 16, 2002
5,739
OK, an update.
Started stripping it apart today (see my thread "Job you wish you'd never started": http://www.seatcupra.net/forums/showthread.php?t=144095 ) :)
Got the waterpump out - and the plastic impeller is just spinning freely on the shaft. I'm amazed it was providing any cooling whatsoever.
It had only been in for ~20k miles too.
Now it has a nice new metal impellered one :)
air121005
1,609
Worcestershire
just had a look at the "job i wish i hadn't started" thread :whistle:.......
and i thought i had to remove a lot of stuff to change the cambelt on my ibiza :rolleyes:
result it only being the water pump and not the head gasket !!!!
was the plastic impeller water pump bought from the dealer?
muddyboots
Oct 16, 2002
5,739
When the cambelt was last changed at 120k by a local garage (who tend to work mainly on VWs), they found the pump was leaking so changed it. Not sure where it came from. I'm lead to believe dealers still supply the plastic ones though ?
Bought the new one online here: http://www.water-pumps.org/VW-Passat-1-9-waterpumps.html
air -> You've changed a cambelt on a PD130 Ibiza ? What sort of work was involved ? (Probably getting another Ibiza again next year....)
air121005
1,609
Worcestershire
me and a mate changed the cambelt, tensioner and water pump a mont or so ago!
took about 3 hours which included a few :whistle: tea breaks
mainly down to the stuff you have to take off to get the cambelt off :blink:
IIRC,
top boost hoses
alternator belt and bottom pulley
vacuum servo thingy :shrug: & water expansion bottle to get the engine mount off (remembering to support the engine ;))
cambelt cover (4 bolts, 1 is really well hidden!)
the water pump is 3 bolts
tensioner 1 bolt
both easy to remove & replace :D
on reflection not the hardest job, certainly not as involved as "jobs you wish you'd never started" :whistle: , in fact looking at that thread, should be a doddle for you :p
air121005
1,609
Worcestershire
my mate had a set of locking tools and we rotated the crank trying to find the holes for 5 mins or more and couldn't the hole :confused:
so we used typex :whistle: marking the crank pulley and casing, and also the cam pulley and head;)
