opinions again, change of heart
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
rite guys after some deliberation, ive decided to not got ko4 hybrid route and spunk my cash on making the power i have (234) more useable
so ive decided to go this route, opinions and anything else wanted on this fellas
quaife lsd £1070 fitted
ths engine mounts £115 delivered
tt wishbone bushes upgrade £80 including new wishbones
forge fmic £550 delivered
mods i already have are in signiture
whaddya reckon guys.... anything ive missed
just 3k for another 40bhp without these mods above i think may be dissapointing tbh
cheers :p
Mar 29, 2007
1,207
Berkshire
If I was willing to keep upgrading my car I would probably do something similar. I'd probably stiffen up the suspension (especially at the rear to stop it squatting on acceleration) and fit an LSD and ARBs. And better brakes would also be a possibilty too.
Mar 29, 2007
1,207
Berkshire
I think the Carrera 4-pots are just rebadged brembo's (same as the LCR has). I was thinking of 6-pot brembos/APs with seperate bells and discs, and ferrodo pads :)
From the sounds of it an LSD would be your next step.
Btw, how did you get to stage 2 without a FMIC and exhaust upgrade?
james walker
May 24, 2007
5,121
retford notts
i have milltek dp and sports cat, fmic asnt required to map stage 2, doesnt alter fuelling etc.
well the 4pots are certainly an upgrade fronm the single pot cupra calipers that were on there!!;)
Mar 29, 2007
1,207
Berkshire
Ah - wasn't in your siggy before :)
I don't suppose you'll notice the engine mounts that much (side-to-side movement) but probably worth doing if you're changing your bushes all round...
james walker
May 24, 2007
5,121
retford notts
engine mounts are very noticeable mate, dogbone as a vast improvement....
all ads to planting the poer onto the road, no use having the bhp if its got nohere to go.
james walker
May 24, 2007
5,121
retford notts
yep, thats hat im on about mate...
dogbone is only half the improvement.
2 top engine mounts really plant the poer don, being stiffer than stock. so the noticeable difference beteen the db and standard ill be the same from the other 2 mounts.
especially on higher powered cars
i have ths db mount, similar density to your ina one. try the ina top mounts and youll love it.
Mar 29, 2007
1,207
Berkshire
Actually I'd say that the dbm is 90% of the improvement as the problem is really with front-to-back movement not side-to-side.
You are right that it will tighten it up a little - all I'm saying is that it will be a very small improvement.
I would consider the THS engine mounts when/if mine become sloppy, as they are about 30% stiffer than stock, but for the dbm the INA was my preference at 90% stiffer.
jaymd
77
Macclesfield - Cheshire
If your going to the trouble of getting a diff then while the box is out have a uprated clutch fitted,as you will change your mine about the turbo route in a few months time.
james walker
May 24, 2007
5,121
retford notts
yep, agree back to back movement is more than side to side.
willie has engine mounts on his and states a big difference.
ths offer the fr3 engine mounts for 100quid ish... scn discount applied afaik.
anyways mine are on the way so ill post differences.
james walker
May 24, 2007
5,121
retford notts
ha ha, new clutch been on 2000 miles anyway mate.
its not my mind that needs changing its the wifes, and that dont get changed very often tbh.
think im going to have to settle for the piddly ko3s power and concentrate on using it effectivly.
not much that keep up in a strait line now anyways:p
Mar 29, 2007
1,207
Berkshire
Yep they're a good price aren't they (that's pretty much what I paid for my dbm alone!).
Yep, let us know what you think...
(I do wonder if the THS dbm's as stiff as you'd like though)
james walker
May 24, 2007
5,121
retford notts
the ths dbm i have is fine mate, massive improvement over stock and no vibrations....
better than the polyflex jobs, cant comment on ina.
jaymd
77
That's ok then.
The Density mounts do make a difference and i'm glad i fitted mine.
