Opel Frontera DTI FMIC in mk3 Cupra
kuprit
113
Hello, don't you think that is better than laguna's?
It´s easier to fit and is fully alloy. All piping needed is in 53mm, no reducers. With 1m of 53mm pipe and 3 elbows, you have fitted it!
I am fitting mine this week so i'll upload pics next week...
Mine is not painted in black :p and i will put this 13 row oil cooler also, here is very hot in summer!
Bye!!!
PAUL HEV
Bananna Bomber!!
Sep 30, 2006
117
grasmere cumbria
I fitted a frontera intercooler on my old nova let and it made a noticable difference.
yeh keep us posted as them frontera i/c's are fairly cheap aswell iirc
PAUL HEV
Bananna Bomber!!
Sep 30, 2006
117
grasmere cumbria
when i got mine a few year ago it £50+vat from a vauxhall breakers
i got mine from a normal 2.8 td frontera and it looks identical to that.
there quite popular with the vauxhall boys so they often get snapped up quick
leegt5
232
Does this not require any angle grinder business >>? Would be interested as well !!
flashbsd
what are the temps like? many peeps odnt see above 40 with the laguna, i dont see over 34 myself with it. 19 now ;)
kuprit
113
Ep!
More pics
I don`t have logs only a little test, go on full throttle about 15 minutes and the car is always under 40ºC with 25ºC external temperature.
Surface area is 600x200, 53mm inlet and outlet diameter.
kuprit
113
You only have to reduce about 1cm one side of the front bar:
For the piping... all you have to do is buy 1m-1'5m of 53mm inox pipe, the cuts will be completly perpendicular. And you'll have to join the pieces with silicone elbows, that's all.
Regards!!!
leegt5
232
Have u got a close up of where youve had to cut ?? Is there no way possible you can have it without having to cut the front bar ???
Can these front bars be got cheaply enough ?? as I'd rather not cut the original !!
