Hi everyone, this is my 1st post here, I hope you guys can point me in the right direction ,
I start from the beginning ,
I bought my leon cupra 20v turbo in February this year as spares or repair due to it needing a new dual mass fly wheel, and the speedo not working, so I replaced the dmf with a solid fly wheel conversion kit,
I replaced the vehicle speed sensor, still didn't work, on further investigation a noticed there was only 2 wires in the vvs plug and 3 pins on the sensor so I stripped back the loom and found the earth wire had been ripped out of the plug and was wrapped up round the loom, also made the fuel gauge go bonkers too
all was good then I discovered that the boot didn't open, so went online typed my
problem in and found you guys, I fixed that
problem by info off this site,
Then I found the crank breather pipe had split, replaced that,
So the
problem I'm having now is
The oil light is flashing on and beeping 3 times, then go's out and then it's fine, I've read the threads on here saying its low oil pressure, but
It only happens when the engine is up to temp,it sometimes does this twice in 5 mins, it's fine when cold which I believe if it was low oil pressure the light would flash when cold
Also, this may be linked but my temp gauge plays up it will sit at the bottom even when the car is up to temp, and the next min it's sat bang in the middle and the next second it's back at the bottom again,
The cars got fsh and there's a receipt in there for having the sump removed and pick up pipe replaced 3k miles ago, it says that a full investigation of the engine was carried out with the sump off and all was good,oil pressure checked and was good
Sorry for the essay but wanted to give as much info as possible
I was hoping some one has had the same
problem/s with oil light and dodgy temp gauge,
