Bill, i have read some where that you run a seat sport baffled sump with a drain back for the catch tank.
What kind of fitting is on the sump for the drain back? push/treaded?
Also where is the is the drain back is it above the baffle or below?
Forgot to ask what size line for the drain back and breather system?
Cheers.
sorry, missed this thread.
I think my fitting is a -3 one on the sump (threaded), which IMHo is a little small.
my Forge oil catch tank has a drain into this via a 1/2" hose which reduces down to the fitting (1/4" ID) and it does seem to work fine.
It has to drain above the baffle level, and tou do need to alter your oi llevel to accomodate the top baffle line as full is too full and it will want to come out when on track. (1/2 way on crossed area is my new max level)
regards
bill
