Having some issues with my REVO stage 2+ CUPRA.
http://www.seatcupra.net/forums/showthread.php?p=3854083
Questioning is if the OEM cat back exhaust could be the main issue, resonator is removed so flow should be pretty good. Looking at the logs from above link you can notice that exhaust temps get to high at occasions.
I am running 3" DP and decat so the first part of hot exhausts travel in the DP should take care of any flow restrictions. Later on when reaching the catback the heat is lowered and the needed exhaust area should be lower, right? When exhausts are hot they expand and the other way when cooled down.
Any thoughts would be greatly appreciated.
