OBD Modifications
ArnauS197
20
Anybody tried this app ?
Autolock upon Exit
I have Kessy Go, I have same version and it is activated but not working
Yep, not working
Reactions: istoyanov
Tell
Autolock upon Exit
I warn people against self locking app mods with kessy incase they lock you out and warn against the one touch ones since you don't what what they really do under the covers. Code it yourself and you can undo it. The developer adding a bug into it may leave your coding a but scrambled. Least that ones is not one click but coding.
I see recent promotion of the 2025 cars do have the walk away self locking and unlocking as you approach. This is a function that was always knocking about it the cars system.
Nov 27, 2023
¿Alguien ha probado esta aplicación?
Bloqueo automático al salir
Tengo Kessy Go, tengo la misma versión y está activada pero no funciona.
Schauen Sie in die Modulinformationen ODx Es ist weniger als 07001 funktioniert nicht
Oct 28, 2024
37
I'm looking for months to get the purple interior led in my leon phev.
I couldnt find the color codes in the Electric 09 module. Is it located anywhere else?
ArnauS197
20
Forget about it, its not possible via ODB. I tried in december and not possible.
Reactions: darkabaz
Tell
Oh yes black box apps if you don't code it yourself per the link. That function was always in the car but not brought out. It's like a tailor making a suite but remove some stitches and it turns into something else.
There have been posts about people getting locked out when they enable these functions. They go quite when I ask. If it's factory enabled you can trust it (perhaps). One person left their keys in the car and it locked them out 😂. Evident the battery went flat in the remote. The car went, OK I'll lock it. There is a lesson there somewhere.
donzi84
18
13
Hello, I have a question: below the values to set the screen to cupra view. I like it but I want to return to normal FR. Someone has the Fr value?
Select Multimedia 5F
- Select Long coding
- Select Car Bodystyle addition
- Set to 1
- Select Vehicle type power stage 2
- Set to Yes
- Select Adaptation
- Select Function configuration hmi
- Select Skinning
- Set to 2
- Select Screenings
- Set to 1
Thanks in advance.
Stefano
cairus
1,215
442
Leon model year 21 but not sure if it is an FR
