OBD Eleven - How and Where to
  • Thread starter Deleted member 103408
  • Start date
Just starting a Thread for OBD11 to show good places to get code, info and video's that can help you make your car better. Please dont post code here, each model has its own thread for VCDS and OBD11 Type coding and that is where it belongs. This thread is to help find information.
Couple points to note before I go further.
VAG make changes to the underlying code and as a result for Leon Pre and Post facelfit MK3's do not always have the same setup, this will also be more obvious as the Digital Dash starts to roll out.
With the facelift cars VAG removed the long coding section from Central Elec control unit 09 all switches were moved into adaptions.
As soon as you get your car or OBD11 Dongle please ensure you take a backup of all the control units this will save your life when something goes badly wrong and you cant work out what you did.
Links
Info on the Pro Tool and how it works
1. OBD11 Pro Board info http://forum.obdeleven.com/thread/2095/new-obd11-pro-help
2. Links to Retrofitting stuff http://forum.obdeleven.com/thread/3238/retrofitting mostly from this site
Coding Links
1. Spanish Site with pre and post facelift Leon coding https://www.clubseatleon.net/viewtopic.php?f=8&t=116700&sid=0b10fd4f82dd80bc90174f197e88c683
1a. Translated version http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=https://www.clubseatleon.net/viewtopic.php?f=8&t=116700&sid=0b10fd4f82dd80bc90174f197e88c683
2. Pre Facelift Leon MK3 http://forum.obdeleven.com/thread/764/coding-adaptations
Excel Sheet with lots of coding picked up from various sites drive.google.com/open?id=0B6_fZT5KO3kTNjJHVndZbWo4bmc
seat leon 5f youtube channel https://www.youtube.com/channel/UCWRzqYR2sThAN4XRfFhmIgg
3. Facelift Leon MK3 http://forum.obdeleven.com/thread/1887/coding-adaptions
3a. Leon MK1 http://lee69.co.uk/Car stuff/Leon/VagcomTodos.pdf
4. Seat Ateca www.seatcupra.net/forums/showthread.php?t=438134
and translate.google.com/translate?hl=en&sl=auto&tl=en&u=https%3A%2F%2Fwww.ateca-forum.de%2Findex.php%2FThread%2F1397-Au%25C3%259Fenspiegel-mit-Absenkung%2F
https://www.clubseatateca.com/threa...deleven-procesos-verificados.2417/#post-98523
5. Seat Ibizia 6j automobiles.fredericbazin.fr/PDF/TutoVCDS/PDF/Ibiza%206J%20VCDS%20Options%20EN.pdf and translate.google.com/translate?hl=en&sl=auto&tl=en&u=https%3A%2F%2Fwww.seat-online.nl%2Fshowthread.php%3F306-Seat-Ibiza-6J-Mogelijkheden-Vag-Com
5a. Seat Ibiza KJ (2017) http://forum.obdeleven.com/thread/3450/2017-ibiza-adaptations-tried-tested
6. Toledo www.clubseattoledo.com/foro/viewtopic.php?t=10531 for the Seat Toledo mk4 using VCDS but can easily be changed for OBD11
7. Seat online - Dutch Site
8. Alhambra (7M) Bj. 1996 to 2009 - http://www.nikutronics.eu/home/info/v-a-g-obd/5-seat-obd-daten/65-alhambra-7m-bj-1996-bis-2009
General Info to help you
1/ Complete listing of control unit on 2014 Cupra http://forum.obdeleven.com/thread/3262/control-unit-setup
2/ Spanish Backup Site for control units - has been moved here https://drive.google.com/drive/fold...,15700168,15700186,15700190,15700201,15700208
, at the time of putting this list together it has Ateca, Leon and Ibiza
3/ Error Codes and how to fix some examples http://forum.obdeleven.com/thread/1783/fix-error-codes
4/ OBD11 Youtube Channel www.youtube.com/channel/UCE3cXM_1ijOo8l3rlwK93wA/videos
5/ OBD11 Help / Wiki page https://voltas-it.helpshift.com/a/obdeleven/?p=android
5A/ How to page on this Forum https://forums.seatcupra.net/index.php?threads/obd11-how-to-section.447624/#post-4812655
6/ How to contact OBD11 Support team directly http://forum.obdeleven.com/thread/1877/contact-app-support-team
7/ Excel Tips and Tricks when using OBD11 http://forum.obdeleven.com/thread/3204/using-excel-exported-data-tips
8. APK File to download latest verision if you have any issues getting it from google store http://redirect.viglink.com/?key=bbb516d91daee20498798694a42dd559&u=https://obdeleven.com/application/OBDeleven.apk
9. Paper on how the lighting channels work https://drive.google.com/open?id=1RE5vA0NFydE6QhAdDJFFjhNpvoBzH5I5
Please add below any good sites you find to help others.
Jimbobcook
6,160
2,540
Great bit of info! Haven't had a chance to properly look into my pro pack stuff so this will be most helpful!
Current - MK2 Leon Cupra R 2010
Previous - MK2 Leon FR 2007
Seen this following questions a few times now so just putting answers to them here as well.
Q What happens to my Pro Account when I want to use more than one device.
A You can connect more than one device (I have used 4) all using the same log in details
Q What happens to my Pro Account when I change phone or internet provider
A Nothing you download the app to new phone and log in using your original details and the history of all your changes (which are stored on OBD11 Servers will be shown to you. Please note when you first connect to your dongle you set a 6 digit passcode you will need to use that when you first connect with your new phone.
Q Why can't I use my pro account activation code again
A The activation code is a one time code, if you have forgotten your log in details contact OBD11 Support via the app.
Q Can I use OBD11 on an IPhone
A Nope and don't expect it to any time soon, like vcds (Windows only) its an android app. You can run Android on a mac using the rights setup but its easier to just go buy a cheap android devise.
Q Can OBD11 Do 0 - 60 times etc
Q Can OBD11 Change Firmware
Q Can OBD11 get round SWAP and Component protection
A No to all of the above
Q Can I use OBD11 to modify the engine / Gearbox settings to get more power output.
A No, this requires much more expensive and technical software to make these changes.
Q Why is my long coding all Zero's in control unit 09
A If its a facelift car then VW Have moved all the long coding functions in Control Unit 09 into Adaptions.
Q Can I remove a car from my Garage (as it was helping out a mate or the car is sold)
A Yes, left swipe and the car is gone from your garage. HOWEVER it does not go from your account if you re instate the car all the history you have will come back. But please note your account only saves the stuff you have done so if you sell the car your history stays with you and new owner does not see it. Visa versa if the new owner makes changes you wont see them.
Q What is the difference between the long Coding with 0 and 1
A The long coding items you see on the first page of long coding (0) are all short cuts that OBD11 Team have put together, when you make a change using one of these you will notice your long coding code will change because it has been updated as well.
Q How can I see changes in my settings when I have not done anything using OBD11
A Two obvious reasons, firstly using long coding 0 as above may show things in you long code string and secondly there are some changes made via the infotainment systems that make changs to the cars settings and are therefore shown as a change.
Q Can I confirm the milage shown on the dash using OBD11
A Unlike VCDS there is not a single process that tells you if all the control units are showing the same milage. See the following http://forum.obdeleven.com/post/14290 but you can check that Display and DSG Box are the same milage.
Q what do i do, i am getting the error " Device not Authorized"
A Contact support via the online help function,
Just adding in to this section stuff that i have found helpful when building pages of shared info.
So using OBD11 You can take a picture of for example all your Live Data options.
Using the following link it will show you how to upload the picture to your google drive (which is free) and then using google software (also free) it can extract all the text from the picture. Free and Easy OCR software to extract the data you want.
https://support.google.com/drive/answer/176692?co=GENIE.Platform=Desktop&hl=en
Release Updates - Just keeping a list of the releases
At the moment both Beta and Production have the same numbers but this list will be for Beta Releases.
13/11/18 Version 0.9.8.4
More fixes to this release.
08/11/18 Version 0.9.8.3
- Fixed parts market crash when same vehicle selected twice
- Fixed K-Line vehicles control units list
- Fixed History missing some elements
06/11/18 Version 0.9.8.2
Fixes to Communication issues on 0.9.8
01/11/18 Version 0.9.8 - Currently not working.
08.10.18 Version 0.9.7
fixed some connection to control unit issues (i.e. Door Control unit)
bug fixes
fixed to update UI after purchase credits
04/10/18 Version 0.9.6
Added Landscape mode
added possibility to watch control unit info without vehicle - more updates to come.
Added User statistics to see how you act with OBD11
28/08/18 Version 0.9.5 - Support Landscape Mode, Allow updated of Control unit info when not connected to the car (eg update long coding descriptions from you chair)
26/06/18 No Version update just a firmware update to fix two issues on Audi and Old VW.
20/06/18 Version 0.9.4 - Updated Credit System Screens, You can now build a Manual, & email, password and link accounts. They also removed the bug where you got credits on the day from each devise. so now you only get max 6 credits.
16/06/18 Version 0.9.3.7 - Update to fix Facebook login issues
24/05/18 Version 0.9.3.6 - T & C and Privacy Updates.
02/05/18 Version 0.9.3.5 - Fixed Live Data swipe through channels
26/04/18 Version 0.9.3.4 - More bug fixes for communication issues.
The APK can be downloaded from here http://redirect.viglink.com/?key=bbb516d91daee20498798694a42dd559&u=https://obdeleven.com/application/OBDeleven.apk and installed manually
plugNNN
26
Hey,
Anyone had any luck activating the traffic sign recognition?
Following the excel spreadsheet I can't find car function adaption gen 2 and so on under adaptions.
I do have the camera installed above the back mirror
plugNNN
26
tom t
365
Anyone had this problem with obdeleven!?
When I am trying to log. I am constantly getting not available messages! When trying toadd them to the charts I want to log!! which is really frustrating any suggestions!? Thanks
@tom t wrong thread mate. this is info link thread.
But are you running beta version as i seem to recall they have fixed some issues
tom t
365
Didn't want to start a new thread ya see. Knew I should have
Sure I'm using the latest version an pro version.
tom t
365
Just deleted app data. Low an behold it all worked fine for a minute whilst looking though engine data an then its done it again
"Q what do i do, i am getting the error " Device not Authorized"
A Contact support via the online help function, "
After recent update my OBDEleven Device stopped working. There was notification that device is not original or authorized. I have proof that it is original so I wrote to developer about it but he says that I have no longer warranty and I should buy new device. He also refused to share previous version of app to check if it is device issue or app update issue. Forcing clients to buy new device by app update is fraudulent practice. There wasn't any information that after warranty period you have to buy new device if you want still use it. If your device stopped working after app update you probably were scammed. You should write about it to European Consumer Centers Network and report it to Google play store.
Is it legal to force to buy new device like that?
Well I have had many updates and not seen Device not authorized however what i have always been told on the OBD11 Forums is to contract support because it appears to be a hardware problem. If you are in the closed testing group then you can leave that and revert to the old version and download that from playstore however they only run one version of the software so its not they wont share, they cant share.
If its a hardware problem then I am afraid if you have (like me) had the device for a number of years then you wont get much out of them (or any other manufacturer for that matter).
There should be a number of old dongles coming up for sale as people migrate to the new dongle.
I am afraid you biggest issue is proving the software update caused the failure (when many other users dont have the problem).
It does not help you I know but if you go to any of the places you suggest then I am afraid these are what they will be looking at.
JoseKaLeL
ARONA Beats Audio Edition (2019-Facelift)
Jan 8, 2020
52
Aguascalientes, México
Links
Coding Links
Can I get the excel File
Please ? The page says me it was deleted.
I’m with a Seat Arona Beats Edition “19
