need to lower it more
you need a 4 wheel laser alignment system which mounts to your wheel and doesn't go on the top. It has 4 legs which clip to your alloy. They need to be careful when attaching it otherwise it can chip your alloy!
There is also a new wheel alignment machine which doesn't need to touch your wheels. Was readin about it whilst having my tyres done. God knows which garages will be able to afford to have that set up.
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
setting camber and castor angles is the garages only problem as the information stored into the database will be diffrent to the new suspesion fitted at my work i can set the toe up and thats it as the camber and castor are thrown way out from it being as low as ppossible :D
