N249 Bypass - Who's done it?
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
mines all gone too, thanks to advice and a helping hand from jonzy! removed everything, bolted the n249 solinoid to the back of the rocker cover and extended the n112 so it could be relocated into the scuttle panel.
engine bay looks alot cleaner!
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
pics below:
basically show the n249 valve bolted to the rocker cover and the vacuum tank removed and the n112 valve relocated to the scuttle panel.
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
autogylm vinyl and rubber care, spray on and leave for a gloss finish or wipe down for a satin finish. good stuff!
Jonzy
still got the ghetto tuning vac hose then dave ;) I knew you wouldnt change it :lol:
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
works really well actually even when the engine bays seriously hot ive had no issues! it will get changed though, im doing a "philw" lol, see my other post mentioning my new red forge fmic hoses have turned up :)
Nov 2, 2004
9,335
South Wales
I'm tempted to put mine back. Been losing boost and seein my N75 duty being maxed out since i done it. Either something is up or my car doesnt like the bypass.
Wilksey
So once the n249 solanoid/valve is no longer connected to any vac lines where do the vac lines end up going to? Do they just sit there no longer connected to the valve or?
CupraTurbo81
Mines completely off and gives a much better throttle response aswell as making it much much smoother to drive at low revs. Recirc valve sounds much crisper at doesn't operate on its own like it use to prior to this mod.
Soz didn't relise how old this threat was!!
Wilksey
as above - So once the n249 solanoid/valve is no longer connected to any vac lines where do the vac lines end up going to? Do they just sit there no longer connected to the valve or?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
The vacum line would then come manifold straight to into the DV then, were as before it come from manifold then n249 and into the dv....
Wilksey
thanks mate im guessing thats by using a t piece to avoid the n249? what about the SAI valve where does the vac hose go from there?
ie
