Another great build thread. Been on a few different forums over the years and even was part of the original 3 that started clubvec. I've never seen such great build threads like on here
Cleared Airbag Light
VCDS Scan found
VCDS-Lite Version: Release 1.0
Monday, 04 February 2013, 21:17:39:0
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01,02,03,08,15,17,19,22,35,36,37,46,56
Address 01: Engine Labels: 038-906-019-ARL.LBL
Controller: 038 906 019 KG
Component: 1,9l R4 EDC G200SG 5342
Coding: 10102
Shop #: WSC 06402
VSSZZZ1MZ5R006923 SEZ7Z0D2664066
2 Faults Found:
18009 - Relay for Supply Voltage Terminal 30 (J317): Implausible Signal
P1601 - 35-00 - -
17071 - ECM Power Relay Control Circuit (J271): Short to Plus
P0687 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: Redir Fail!
Controller: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00001
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.LBL
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00044
Shop #: WSC 06402
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00591 - Seat Belt Switch; Left (E24)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: Redir Fail!
Controller: 1M0 920 922 E
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 04404
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0004
Coding: 00259
Shop #: WSC 06402
1 Fault Found:
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
End --------------------------------------------------------------------------------------------------
Removed air filter from CAI - cleaned and refitted ready for MOT tomorrow, with weather as it is I have fitted the filter in the bay rather than in the wing
will refit in wing when weather improves
Showing the car some love again
Got the vacuum and cleaning kit out this morning and gave the interior a good clean in the snow!!!
then Timing belt, waterpump and alternator tensioner changed at mates rates and I then changed the oil, oil filter and pollen filter in the snow.
