More Idle issues on my LC
sebasti0n
81
I just changed the Temp coolant sensor, which sorted out most of my starting problems.....
The LC was fine for the last couple of weeks, but i noticed the last couple of times that ive started the car, that the idle seems to flutter a lot and until the car warms up, when I come to a stop, the revs drop to around 500 rpm, then flies back up to a 1000 rpm, then settles to the normal setting....
Engine management light is not on...
anyone els experienced a similar problem and what was the solution ???
Thanks.
smiff
Newbie
Jun 14, 2006
232
stoke on trent
I had a problem with the idle on my lc so i decided to check the throtle body and found when i pushed it there was a lip of dirt and oil i cleaned it all out with carb cleaner and did a throtle reset and its fine now
