MK4 Ibiza - What Alloy Wheels Fit Archive!
May 6, 2009
3,500
Northallerton, N yorks
15mm is the lowest you can get adapters, unless you go machine them down and cut your bolts down even more.
Gonna struggle on the front possibly, depending on tyre choice. Back would have been better in 20-25 like Jordan said, also depending on tyre choice. I've had a few sets of 17x7.5's on my old Ibiza. Et35 front with 195-40-17 and et15 rear with 195-40-17 worked best and sat really well
May 6, 2009
3,500
Not the best of pictures to show but this is 17x7.5 et35 front et15 rear:
Et30 17x7:
Et33 17x8 fronts et25 rears on my Cupra:
Just to give you some idea. Et26 17x7.5 will be pushing it when your lowered unless you stick rubber band tyres on. Would look good if you got it sitting right though, sure you'll do it :)
touge
76
Nor-Which
Okay, So bear with me here.
I've recently noticed that the later MG's had a 5x100 stud pattern, and also that the alloys resemble the hell out of a certain set of BBS alloys that make me sex wee [a little bit]
Now, let's face it MG parts are dirt cheap and these alloys are no different. I don't want 18's but am waiting for some 17's to come up.
What do you think?
http://www.ebay.co.uk/itm/MG-rover-...r_Wheels_ET&hash=item43accdb272#ht_500wt_1413
Brilliant idea mate.
Never knew the MG's made 5 stud.
I've only seen the 4 stud ones, and wished they would make 5 studs because they do look really nice.
I just wouldn't post links on here in case someone else bids on them, haha! :p
touge
76
Nor-Which
Haha as i said im not after 18s :D
... there is a set on gumtree which are also 18, guy wants 250 or summat, they are located in scotland i think! If i find any 17s ill be keeping shtum about them ;)
Jordanwaterhous
Motorsport > Scene
Sep 15, 2009
1,936
Leeds
www.facebook.com
What do you think?
You'll probably need spigot rings for them
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
What do you think?
MG ZT, 5x100, offset is 38 to 45 and bore is 56.1
Ibiza Mk4, 5x100, offset is 35 to 45 and bore is 57.1
They will fit in terms of PCD and offset, but the bores will need widening by 1mm! Any local, good engineering firm will be able to do this for you f you have your heart set on the wheels.
Info from: http://www.carlsalter.com/all-wheel-fitments.html
