Well well well . . .
Not alot has happened recently but i decided to bring the car off the road and sorn it since christmas. The car needed a bit of tlc. I feel like i have neglected the car lately but i will put this down to the purchase and renervation of my house.
While the car is off the road i plan on general service work and also modifications. Here is what i have planned:
Timing belt and water pump
Oil and filter change
Replace ns outer cv boot
Replace leaking radiator
Tidy up boost gauge wiring/tubing
Look at fitting new os lower front grille
Fix inop aircon
Remove and possibly rebuild gearbox
Modifications:
Milltek decat pipe
Milltek centre section (non res)
Custom downturned backbox
Bosio r783 nozzles fitted to the pd130 injector bodies
Allard egr delete pipe
Superpro rear engine bush
Aem water methanol injection kit
Firstly a few days before the car came off the road i fitted 10mm front wheels spacers but no fitted pics (yet):
I fixed my nackered door microswitch by replacing just the switch
And a few nights back i removed the gearbox to get stripped down/rebuilt. I have been struggling to get 1st and reverse occasionally. On removing the gearbox i noticed no sign of grease on the input shaft but still stripped the box to check the selector forks
Also i have purchased a 2nd hand cylinder head inc valves,cam and rocker cover. Im unsure what im going to be doing with this yet but big valves, with port and polish may be on the cards
I will keep this progress up as i go
Ste
