Mk4 Bulb upgrades
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
cheers guys thats a real help
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
right just ordered
H1 = H1 Philips Vision Plus 50% bulbs (pair)
H3 = H3 Philips Blue Vision Bulbs (pair)
501 = 501 LED Super Bright White
already have
H7 = H7 Ring Ultra Xenon bulbs (pair)
Nathanio
1,226
West Sussex
www.w1pcs.co.uk
From the autobulbsdirect car search data base:
UK & EUROPE
SELECTED VEHICLE
SEAT IBIZA MK4 2002 ONWARDS
BULB SEARCH RESULTS
MAIN/HIGH BEAM H1
DIPPED/LOW BEAM H7
FOG LIGHT H3
SIDE/PARKING LIGHT 501
FRONT INDICATOR 581
You can now click on the selected bulbs for your vehicle to view our comprehensive range of upgrade bulbs.
By clicking on your selected bulb, you will be directed to the correct page on the website. This window will minimise so you can get back to these results easily.
mexicorich
Newbie
Apr 17, 2006
261
Hartlepool
Well mine definitely have a wire lead off the back which would rule out H1 and my owners manual says H3 for double reflector lights?
Nathanio
1,226
West Sussex
www.w1pcs.co.uk
Have you read through the thread? This has already been discussed and sorted out. The ABD website is correct !
What year is it? I know someone with a mk4 and it had H1 and H7s in the headlights
mexicorich
Newbie
Apr 17, 2006
261
Hartlepool
How has it been sorted out Nathanio?
So some website says H1s are used - they know better than Seat do they?
So is the Seat owners manual definitely wrong then?
mexicorich
Newbie
Apr 17, 2006
261
Hartlepool
Well my 2003 Ibiza Owners manual states that the main beam are H3
I presume it's right unless its a misprint
My own car certainly is NOT currently fitted with H1
dasmith83
Formerly "Dave FR PD130"
Jul 1, 2006
602
Kent
My manual says-
Single reflector headlamps:
  • full/dipped beam 12v 60/55W H4
  • indicator 12V/PY 21W
  • position lamp 12/W5W
Double reflector headlamps:
  • dipped beam 12V/55W H7
  • full beam 12v/55W H3
  • indicator 12V/PY21W
  • position lights 12V/W5W
I have an '07 FR PD130 (so i guess thats what the manual is for)....I hope that clears it up a little
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
yup i've got the wrong bulbs, they are H3's on main beam so i just left my fogs standerd for now, i know someone who has H1's so i can sell em on so no biggy,
took about 20 min to change two main beam and one sidelight and an 1h 10min for the second sidelight :censored: but there all changed now and look v. good, just wondered though on the led501's i got it says that bulb life is not garenteed, but autobulbs also sent me some 501 w5w bulbs that i did not order and are not on the invoice, do you think they're a free'bee because the leds are unreliable:shrug:
EdButler
713
Sheffield
They usually send "Blue Look" (what a load of rubbish" free 501's now, so they match up with your dipped beams.
Unfortunately the LED sidelights are crap too - even China's finest! They have terrible onboard voltage regulators that either dont regulate properly (made for 12 instead of 14.4 which the alternator produces) and/or they get so hot the de-nature the LED - either way they start to flicker and will attract Police attention without you even knowing!
Mr Cellotape
AKA Mr Ribbed
May 9, 2006
1,283
Warwickshire once.
If you want to stay with Halogens you'll need to change both mains and dipped. Sounds like you've done H7 (dipped) but still need to do H1s (Main). I would go for Osrams or Philips to be honest for halogens and for maximum light you'll need 4300/6000k HIDs.
Just so you know.....
The 4,300K lamps will be a cool white light.
The 6,000K lamps will be a daylight light.
The thing to look out for between lamp types if you want the brightest lamps is the initial lamp lumens, basically the higher this is the brighter the light output.
Additionally it would be worth looking at the lamp life hours, as you don't want to be changing them too often, you really want to be looking for something above 10,000 hours if not in the 20,000 hours region if you don't want to be messing about with lamps all the time.
Hope this helps.
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
from autobulbs they give out free "gifts" if u spend over a certain sum of money with Every order to do with bulbs or not.... i hope they change the led's to 14.4v because it is quite annoying!! i have led sidelights and interior and so far i need to re-change the sidelights due to a failiure... :S
