MK4 Brake Upgrades
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
is it true that you do not require the actuall calliper from the TT just the carrier disc & pads, apparently the calliper is exactly the same on the facelift ibiza as the tt 225, so just the carrier is needed which adopts the old calliper and new discs. Anybody confirm this?
wizzle_ibiza_fr
46
hi, i have a pd100 not sure wat size the discs are but wud a pair off the newest polo gti fit and wat size are they? im guessing they wud b 288mm like the fr? and would it be worth the upgrade or just go for the tt setup?
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
To fit either the 288mm set up or the 312mm set up you will need new hubs off a pd130 or pd160. I have my 288mm set up in the garage if your interested;)
wizzle_ibiza_fr
46
discs calipers and hubs? how much is on the discs? and how much you want for it all? my mate was gona sell me the 2 discs for 20 quid
dave_chandler
i have a 2.0 sport. what would i have to do to be able to fit either 288mm or 312mm discs etc? which would be the cheapest way of doing this?
st10587
Oct 4, 2007
3,669
Hindhead
as far as i know you would have to change your hubs to. the cheapest way is to go to a scrappy for 2nd hand ones or try someone like euro car parts or gsf as they will be cheaper then the dealers
dave_chandler
so what would the difference be between my hubs and the hubs off of a pd130 or pd160?
cheers dave
st10587
Oct 4, 2007
3,669
Hindhead
cheers dave
at a guess it will be the spacing for where the carrier bolt on to the hub. im not 100% on this so dont hold me to it. if i was you id phone a half decent dealer and ask for the part number for the hubs for yours then as for the number of the hubs for a pd130/pd160
bertrum
cheers dave
If you have the 256mm FSIII brakes then you will need the new hubs. New from dealers are ~£90 EACH. I picked up a full Furby VRS setup from breakers for £230.
The differences are that the hubs with the smaller brakes have the caliper carrier built into the hub, whereas the LUCAS (288mm) or 312mm have a separate caliper carrier.
bertrum
adam... My wheels and your wheels are two of the 16s you can get that DO clear the 312s, IIRC.
