  • Total voters
    980
sdolman84
74
41
To clarify that is it good to get in different gears or just keep getting the car to do between 1-3000 revs by altering speed
I can get down to 30mph in gear 6 !
I think its just a matter of varying the revs when possible and at higher speeds you'd do this varying the speed rather than gear changes i presume.. check this video out...
The Daily Meme
Insta: @thatredcupra
Jan 3, 2018
912
467
Cambridge
And here’s my luck
I'd just point out mate, that's the same type of self tapping screw that is used to screw the plastic panels to the inside of the wheel arch. I know because I had them off at the weekend. Either something's fallen off your car, or that screw was in there when it was delivered.
10Pcs-OEM-Inner-Hexagon-Self-tapping-Screws-Bolt-M5-16-For-A3-A4-A5-A6-A7.jpg_q50.jpg
Betts-4
620
207
O
o yer I knew that and it’s clearly old and is in my rear tyre
100 percent was in there from delivery becuase when I drove it the pressure warning came on and the Psi was 27
I pumped it up to 44 and overnight for like 12 hours it went down 7 so it’s been going down for days clearly before delivery
they said it’s my issue
Invertigo
169
77
Problem with something like a screw in a tyre is, unless you pick it up at your delivery inspection, there really isnt a way to prove you didn't drive over it 30 seconds into your ownership. At least a £10 repair isn't a big issue.
Denno
67
22
Had email from Zen today, car ready to be arranged for delivery, ordered 21st November non-lux car.
Reactions: Gooday
Invertigo
169
77
Any idea which port and dealer yours was through? I know they use a few different ones, mine was ordered 20th and is still showing as en route to dealer, expect yours may have been collected a bit faster from the port. Plus, Grimsby and Tyne got bumped back a bit as the ship made a diversion over to Emden to load up some more VW group cars.
Denno
67
22
To be honest I’ve not really chased up about it since my order. I never had a tracking number or anything like that, just left it fate. Must admit was bit surprised to see the email that it’s ready.
Betts-4
620
207
How comes the advance driving pack does not include blind spot recognition
please can someone confirm what it has so I can check I have it
I defo have the traffic sign recognition,not been out at night yet so can’t check hi beam
Anyone know how the hi beam works, does it just come on and off auto if it’s really dark road or do i set it ?
TimT
30
7
Mk3/3.5 Leon Cupras dont have blind spot recognition available, you probably confused it with something else. for highbeam you need to have 'auto' on the lightswitch and then when driving you push the lightning stick forward and it should bring up an "A" or something like that on your digital dash.
Betts-4
620
207
It’s just I have it on my Ateca
I’m not sure why anyone would pay for high beam assist and traffic sign recognition,they both are pretty useless and it cost like over £1000 I believe
CupraGeezer
356
164
Ateca is a much newer model than the Mk.3 Leon, though. Yes, some technology (e.g. virtual cockpit) has been introduced with the MY updates but many systems have been held back for the Mk.4.
Don't agree with that, I think the high beam assist is brilliant and the sign recognition is decent given the council's predilection for putting signs very close to junctions.
Betts-4
620
207
Maybe I need some explanation of what they both actually do
having been in it all day all it did was tell me the speed limit,no other signs came up and if your driving properly you should be seeing the speed limit signs lol
high beam is good but all it does is remove a simple flick of a stick we all rarely use
I can see it being handy with council cutting street lighting but most roads you don’t need high beam
BS1
82
29
I agree with this to a certain extent - Engines like what’s in Nissan GTR are Hand built and Nissan admit none of their engines produce exactly the same horsepower - because there is room for error in a hand built process. The likes of these 2.0 EA888’s are mass produced to fine tolerances (I work in the industry - we manufacture to less than 30 microns for most precision parts) so I think as long as you vary the rpm ie don’t idle it and don’t rag it when it’s cold or redline it all the time you
Will be alright. At least that’s what I’m telling myself as I can’t help driving it quickly!! Tried to use paddles to keep it going above 5000rpm however but I think for the brief moments it’s in the higher rev ranges probably help it to ‘break in’
CupraGeezer
356
164
High beam is good but all it does is remove a simple flick of a stick we all rarely use. I can see it being handy with council cutting street lighting but most roads you don’t need high beam
Depends where you live I guess. I would say that only 15% of my daily commute has street lights. OK, we're now heading into a period where I commute in the daylight but for at least 5 months of the year, high beam is invaluable.
Reactions: Tivver500
Betts-4
620
207
Fair enough,my commute involves a single road for about 30 seconds the rest is lit
Betts-4
620
207
It says don’t go over 4000 revs ?
so far I think 3000 is max mine has gone to,I’m just driving in comfort with slightly less than normal throttle between 5-30%
It’s nearly done 200 miles
I think at 300 I’ll will maybe give it a bit more 3500 max and then 600 onwards open it up
that seems to fit in with all the advice don’t baby it but nurture it
In comfort to be fair it changes gear between 2-2500 revs
