MK2 door speaker cabling help!
MomoMK2
137
York
also posted in ICE:
how the hell do i run speaker cable through the front door seals on my MK2 ibiza?
this problem has had me baffled for a while but im sure loads of ppl have done it in the past.
any advice?
cheers. tom.
feed it through the grommet near the door hinge, tis a rubber tube thingy :)
pic to help:
Below the metal door hinge ;)
MarkW
Chris
Apr 4, 2007
210
Edingburgh
Do they usually look like that above? Mine has got a mahussive ribbed rubber sleeve thing covering over hundreds of cables.
Oh, with the wiring on mine, I was a cowboy and used the existing, just solder the 4 cables in the dash together into two, connect to the crossover and work from there.
I really couldn't be arsed to rewire the whole lot like I did on my last car there and then.. Will probably be doing it soon though. Especially if I get new componenets!
GAL
mines the same with the rubber covering hundreds of cables.
think the guy who had mine before me used the electric mirror wires to put the speakers in the door.
the wires on the door go into a plug. so i think this is why my electric mirrors were made obcelete. not sure how else you can put extra wires through unless theres a free socket in the plug. or you could drill a hole through the plug to feed wires through, if theres space!
GAL
oy yeah. you can unscrew the plug! (not sure if youve had it off- or what you know about it)
dirtbiker
274
Southampton / Nottingham
The budget models (like mine :rolleyes:) have just the rubber blanking gromet where the wires for the electric windows etc. are run on the more expensive models. Its easy enough to drill/poke a hole through the gromet to run the speaker wires...
MomoMK2
137
York
cheers for the advice dude but ive got that far! (give me some credit lol)
ive tried and tried and tried both sides to feed cable through and just cant get it to go through!
MomoMK2
137
York
nope
but it came with evo style mirrors with indicators (which ive since changes thank god), the single wire for the lights ran through and i tried to use that but the speaker cable wont fit through the same gap,
any ideas? this is really bugging me, got myself i 6 way jbl amp a couple of months ago just need to conquer this and ill be all set!
MomoMK2
137
York
well i havent had any luck as of yet!
theres 2 separate plugs which are removable from the car-side, ive tested and speakers and electric windows still work when one of them is removed so ive honestly no idea what the wires are for, ill try from there when ive got some light tomorow.
you any idea if the whole plastic block is removable? it has a spanner type shape on the outside so maybe so but its far too slim/soft or any tools i have to hand and dont really fancy getting the drill out.
ill have another go tomorow and let you know what happens. cheers dude, by the way sweet car and website, kinda my bible lol.
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
Oh, with the wiring on mine, I was a cowboy and used the existing, just solder the 4 cables in the dash together into two, connect to the crossover and work from there. QUOTE]
Ive got the rubber sleeve thing, but it will only have the wires for my electric windows in it so i should manage to get speaker wires through. Will be attempting this weekend!!
I was abit of a cowboy aswell when i put an upgraded set of 10cm speakers in the dash. I used the existing wiring, cut it and put the wires into a strip/block connector. The two positive on one side and the 2 negative on the other. Will make it easier when wiring up my crossovers.
MarkW
Chris
Apr 4, 2007
210
Edingburgh
I need to check what room I have on mine then.... I've got speakers, electric mirrors, central locking and electric windows. I'm worried about rewiring them now!!!
CraigW
Craig.
Apr 12, 2007
4,607
I was inspecting that grommet thing and it is a wiring plug.
It is like a plug in the hole with the wires going into it then the same wires coming out the other side.
Take your door cards off, you may already have speaker wires there. I found a speaker cable on each side so im just going to adapt the standard wiring to fit my crossovers and speakers/tweeters!!
