Do they usually look like that above? Mine has got a mahussive ribbed rubber sleeve thing covering over hundreds of cables.
Oh, with the wiring on mine, I was a cowboy and used the existing, just solder the 4 cables in the dash together into two, connect to the crossover and work from there. QUOTE]
Ive got the rubber sleeve thing, but it will only have the wires for my electric windows in it so i should manage to get speaker wires through. Will be attempting this weekend!!
I was abit of a cowboy aswell when i put an upgraded set of 10cm speakers in the dash. I used the existing wiring, cut it and put the wires into a strip/block connector. The two positive on one side and the 2 negative on the other. Will make it easier when wiring up my crossovers.
