MK1 Leon GT2x Build - thats it folks
jamiebennett81
another quick question as AMD have the turbo and manni currently off, the Actuator is bent (it came back from CR turbos like this) so i presume it is meant to look like this?
if its bent, how can it be adjusted....
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
i just got some nordlock washers today and looking at k nut's like rob don got but dont know if be able to changed that last nut under mani without having to take it all off like i gues AMD are having to for jamie's.
Oct 17, 2006
2,141
Mid Wales
Jamie - surely if as you indicated in post #814, the poor fit and leak is being caused by the bolts stretching, the same problem will persist regardless of whether you have locking nuts fitted or not?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
nordlocs have rising ramps on them as well as serrations which is why they claim to hold things tight in expansion/contraction/vibrating conditions.
where did you get your nordlocs?
jamiebennett81
Many turbos have bent actuator rods. Both my VF34 and TD05 are that way.
thanks mate, I thought it was fine, just AMD panicking me, but needed it confirmed:)
I will check with Simon tomorrow that nordlocs are being fitted with the bolts that are being made up
Thanks Bill;)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
I have a keyring with nordlocs forming it from a trade show years ago.. seemed like a neat good idea on a product I was involved in making @ the time. It was a coriolis massflow meter, which vibratred at ~200hz as part of its function and needed to operate from -20'C to +250'C or higher at times. If anything was such an environment for showing failures it was that.
Neat yet simple solution on the face of it
HTC
Sep 2, 2004
421
I like the look of those K nuts. My kit came with nord locks, which I was impressed with.
Out of interest, my turbo is underslung and held up by bolts. Would I (and the rest of us) be better off using a stud and nuts?
