MK1 Leon FR TDI, Stealth Edition [PREPPING FOR SALE]
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
OK, finished building and install my custom air freshener system.
Bit silly i know but was bored with 6 weeks off work and with magic trees only lasting about 2 days thought i would design something. works well actually and love the Febreze Caribbean Paradise smell. Smelly farts in the car are a thing of the past :)
Parts Needed
Triumph Tudor 500ml washer bottle and stainless bracket - £15
Ring Automotive universal 12v screenwash pump -£12
5m clear 3.2mm washer tubing -£3
One way valve - £2.50
12v electric shut off solenoid valve - £12
1/4" BSP to 4mm Hose tail connectors x2 - £5
1/4" BSP Bonded washers - £1.50
Push to power switch - £2
5m 25amp red power wiring - £3
Various spade connectors and terminal blocks
2x 300ml Febreze Caribbean Paradise air freshener - £4
Febreze novel spray (taken apart from used Febreze can)
Total = £60
Vid in action
nice :clap:
Sep 18, 2009
2,443
Shropshire
Ok My rear LCR calipers have finished being fully refurbished with red polymer coating and new seals, bleed screws etc and look brand new from the state they was in when i got them. Also got some EBC Ultimax 256mm vented discs and some Ferodo DS2500 pads, so should be a good rear upgrade from the standard ones. Not sure if i should get some LCR rear disc shields or cut the lip of the FR rear ones ?
Also got some Porsche Boxster S 3.2 Brembo rear calipers to go on the front but will only allow for a 312mm disc, so iam gonna get rid of them and either go for the Boxster front calipers for a 330mm disc or the R32 calipers for a 335mm disc.
Before
Refurbed
Porsche Boxster Brembo Calipers
2,443
Shropshire
I would recommend getting the LCR disk guards if u can - I had the lip cut off my FR ones and it makes the rear disks look quite small.
yes was thinking that, will have to get a price for them from the dealers, bet there not cheap though but will have a more OEM look.
hear there a pain to change too
Sep 18, 2009
2,443
Shropshire
I've started putting my air fresheners on the pollen filter to get the smell through the vents.
Stops the car being overpowering of air freshener from being sat with the magic tree in it.
did think of that too afterwards, and its the cheapest and easiest way of doing it lol
did you put it on top of or under the filter ?
