mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
Hello Powernut.
I, like Aimez, have been reading and enjoying your thread on the other VW forum (UK-MkIVs) and did not realise you were a member on here with a similar thread. :thumbup: I have looked at your other project, the beetle and am amazed at that as well. [B)] Have you put a vr6 engine in a Polo or am I thinking of someone else?
I have questions about your brakes, firstly how on earth did you break the carriers, did the sliders seize up? Are you (or have you) going to upgrade the brake discs, putting bigger and/or grooved discs on the car, as I see you have recently added better callipers?
cheers yep poped a 2.8 complete engine gearbox runing gear and loom in a vr6 polo ,:lol:
regards bracks just pop some g60s on ,,,/ps the carriers were fitted to a mk1 caddy 312mm discs and stock 4 motion calipares which was caused between the calipar not been tight and braking and too mutch brake ing force at high speed on a private road ,now runing wilwoods and discs on my cddy with no probs ,,,,:)
powernut
475
well im runind 288 as the wilwoods just clear due to alloys
so went out testing , all i can say is why didnt i fit these first off , dosent have a problem locking the wheels , and ive also use a t in the rear brakes removed the conpansator valves ,and adjusted the servo up which helps loads
managed to get a couple of updates nothing great thow
first made adaptors and made sure everthing algines up on the calipars
also made so i can remove them to go back to stock use too
then quick rub down andgave door some spray , (was fed up of looking at a blue door
then rubbed it down to add to rough affect lol
next , i wanted more rear wheel camber so added a bit
quick ruber over rear window with buffer
moved wiper so stops in centre maybe a daft idea but works lol
other then this this seem to be runing fine
gave them some proper hard braking , no problems yet
powernut
475
will guys new clutch is bedding in , nicely no slip at 20psi ,, tuck my mate in for \a spin ,thought he was going to pass out lol
powernut
475
has too sounds a nice burble with the side pipe and v6 24v straight thew and a loud screem of boost as it passes lol
ill try get some up soon
powernut
475
heres a short 8psi vide unsure if u guys saw it , me on youtube ,, next will be a 20psi
powernut
475
wasnt over the top , wasnt happy as the dam mic disorted and u didnt hear the dam turbo boost whistle and hitting limiter , ill try a outside video for the next one lol, u may get the full effect
powernut
475
i cant imagine what 20psi will be like. i was wondering what sort of speed you went up to after you went round that corsa
shouldnt really meantion but was hit over 100 in a short space , 20psi is totaly differnert lol
powernut
475
video removed guys but if u search for adaptorman on youtube thats me , and the next one wil be added when ive a bit more time ...:D
air121005
1,609
Worcestershire
it wasn't the video i was reffering too, it was your post (no.453) "shouldn't really mention" ;)
the video just shows you overtaking a car :shrug:
