The Milltek systems dont use baffles..havent done for a long while.
They utilise straight perforated tube with acoustic material packed around it to form the internals of the silencer.
Opening the silencer up will only cause you problems in the long run TBH.
I would advise putting a downpipe with either cat or decat and use a non-res centre section, this will give an increase in sound and a deeper tone.
I'll say again, you need...
3" DP
3" Decat/Race-Cat
2.5" or larger Cat-Back with no middle box and a very small (custom) Back-Box that uses a straight through design i.e. cylindrical silencer with pipe from mid-pipe > tail pipe surrounded by a little muffling material (depending on what sound you want).
Ok let's clear this up once and for all.....
The Milltek system for the
mk1 Seat Leon Cupra (180) is NOT loud, the non-resonated version has slightly deeper , ever so slightly, not noticeable at all, the resonated version sounds like the standard exhaust,
I have, a 3" inch downpipe:
A 2.5" inch Pure De-Cat:
and a 2.5" 'Non-resonated' Milltek cat-back system:
So let's go through that again
3" Inch Turbo Back Down-pipe
2.5" Inch Pure De-Cat
2.5" Milltek Non-Resonated Cat-Back system
This is NOT loud at ALL! I can hear my A'Pexi Air Filter ABOVE the Milltek System:
This tiny (compared to Jetex) Air Filter is LOUDER then a Non-Resonated Milltek Cat-Back system
Let's go back and see my previous exhaust set-up
Resonate Centre Section:
Almost the same size back-box as the resonator! / silencer:
This set-up above, popped and banged like mad, had such a SEXY burble on IDLE, and on full throttle is sounded awesome! seriously not like a subaru / evo, just perfect
I don't understand why someone has suggested that these engines should NOT pop and bang? it's bad for them? over-fuelling
My engines running spot on, timings are near perfect, 02 sensor readings are spot one.
