MAP sensor...?
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
www.wepaintanypart.co.uk
Right, checked the pipework for leaks, no luck, everything is tight and secure as it should, used soapy water and no bubbles anywhere. So I'm considering whether it's the MAP sensor? The MAF went a couple weeks back so maybe the MAP has had it's day too? No fault codes on the ECU.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
rare for a map sensor to go dan... is it fully flush to the housing on the toyosprts sensor pipe?
also check the o ring in the sensor, could have split causing it to leak slightly.
remind me of your running issues again mate?
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
Only boosts to about 10 psi mate full throttle, no recirc sound or anything when I let off, feels like it's holding back and when it reaches 10psi it drops back to about 5 :(
I'll check the sensor and the ring tomorrow
723
cumbria
www.facebook.com
Mate maybe nothing to do with your problem but have you checked your DV,serviced it lately?mine was running crap the other weekend,no boost as such and it wasn't until I realised I couldn't hear the DV that I checked it,after a service was as good as new again,just a thought...
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
Looks like you might actually be right mate I fitted the old Bosch DV and it ran better but still dropped off boost when I floored it so I suppose that's due to a weak spring.
A mate has said it's possible to block the DV mount off?
Would a dual piston DV work?
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
I've heard that a dual piston can work on the vag engine, i'm sure stef cupra has a hks ssqv on his with no running problems
Jul 29, 2006
723
cumbria
www.facebook.com
Do you have the forge DV mate? if so give forge a ring and ask nicely they may send you a service kit out,otherwise they don't cost a great deal mate,just new O rings,grease,and internal bit.
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
Yeah I've got Awesome bookmarked mate they've got those DV's cheap on ebay too atm thanks
Forge TIP mate. Just seems strange as with the OEM DV it only boosted as high as the uprated one but didn't drop back as far under throttle.
