jamiebennett81
ok, tried fitting the MBC today and I am confused
I understand you still leave the N75 plugged in electronically - DONE
the N75 fits into the TIP, so I took it out and blocked off the TIP - DONE
the vac line from the actuator fits to the underneath of the MBC - DONE
the vac line into the charge pipe runs onto the side inlet of the MBC - DONE
MBC is wound right down and its running silly boost
what am I doing wrong?
