MAJOR HELP NEEDED plz
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
Hay lads in a bit of a hurry as av got work, but anyway I tried to fit a sony headunit today and yep I need to swap the wires round so it holds memory, What wires do I swap? as I dont have a red and yellow, the pin numbers would help a lot here. Also how do I get the pins out they seem to be dam near welded in. Any help much appreciated
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
yer but I dont know what the cables are that are in, Im seriously confused. Its a sony gt30rn headunit. I have the pins here or what they need to be for sony:
1-NC
2-NC
3-NC
4-Backup
5-Ant Rem
6-NC
7-ACC
8-GND
I have no idea what they are as default but apparantly they are wrong. And how do I change the wire from the plug do I swap the connectors in the plug round?
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
so themulti plug (chocolate block) the wires are in the wrong placesso the head unit aint working??? if you know what wires go where cut the two connectors and join and heat shrink all the wires togetha
soz if im wrong as im useless with audio :whistle: just trying to help you out
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
**going to go take sume pics will update in a moe** however it is in the garage and I cant be botherd 2 move the nissan and honda off the drive to take mine out so, might be dark we shall see.
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
right here we go with the pics
The Headunit
The Plug
The back of the plug
The installation guide for the headunit
http://pdf.crse.com/manuals/2664272121.pdf
Any help much appreciated chears guys
MK8
You should have an adapter for the Sony that will go between the wires from your car (the ones in your photo) into the back of the Sony. On THAT wiring loom there will be a red wire and yellow, with bullet connectors half way through. Just swap these round.
Have you got the wiring loom thats inbetween the car and head unit? You must do as youve got the head unit working in the forst pic
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
erm I dont I just pluged the original plug in the back as it fitted and worked well. Where do I get this wiring loom from? or more where can I get it as it didnt come with one lol
CHR15B
2,567
9
Scotland
That looks like the one you should have. I'd go for it (If it fits your radio).
The one you use at the moment, is it modified at all?
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
the one I have has exactly thre same fitting sockets at the alan one I just need to swap the live and permanent live around so I dont have a clue what wire I need for that any help would be greatly appreciated as Im rather clueless
MK8
I just happen to have a Sony Headunit on my desk, as well as a digital camera, so I took some pics that might help you out!
This is my Sony Headunit, with the wiring loom attatched:
This is the wiring loom that went inbetween the Seat Block connectors and the Sony head unit:
All I did was replace the yellow and red wires like so:
And then plugged the block connectors into the corresponding Seat ones.
I hope this helps?
Btw, if your connecting an amplifier, use the blue one with white stripes (you can see it from my pics) as the remote wire.
BlackFR
1,724
Not too far away
Should help
All you need to do is swap 4 + 7 over. But you also need to make sure that 3 is disconnected. Make sure pin 1 is also disconnected if this is not compatible with your head unit.
I wouldn't butcher about with the factory connectors, it is possible to take the crimps out of them and reposition them but it involves the use of long pointy tweezers!
The ebay link doesn't look suitable for your application at all. What you need is a PC2-69-4 http://thebassbin.co.uk/shop/product/products_id/3082.html which will also be available from halfords...
You might also need a PC5-52 if your radio reception sucks. http://www.autoleads.co.uk/database/productImages/PC5-52.jpg
This is required to power the antenna amplifier which is located in the base of the antenna.
