MAF Values - REVO
TimD
472
Took the car for a quick log this evening in the pouring rain..
I'll get the full log spreadsheet tomorrow but having a quick glance before the battery died the the maf had topped out at around 144g/s
Is this good or bad?
If it's bad do i need to check anything else before paying for a new MAF?
Tim
TimD
472
3rd gear from 2.5 to 6k rpm.
I'll try a fourth gear run this evening, i wont be going out if it's raining again was scary trying to slow the car down whilst hitting loads of surface water, lol!
It has a crappy stainless steel filter fitted, i do intend on having this changed.
TimD
472
Hopefully attach a snippet from the log..
Run done in 3rd gear!
Code:
Group C:	'002
	RPM	Load	Inj. On Time	Mass Flow
TIME
STAMP	 /min	%	 ms	 g/s
50.26	2960	114.3	14.76	71.17
51.76	3480	169.2	22.55	114.86
53.25	4080	169.9	23.78	133.08
54.75	4600	159.4	22.96	140.67
56.16	5040	150.4	22.14	146.53
57.65	5440	140.6	21.32	145.78
59.17	5720	132.3	20.91	143.58
60.66	6000	127.1	20.5	144.58
Will do the boost one tonight if the weather stays the same, cheers :)
Jonzy
PhilW had similar issues, pulling 144-145g/s, same result when using my maf too (proven 155+). Turned out it was his airfilter, switched back to his dynatwist and the figures improved, 154g/s.
Im sure he will correct me if im wrong ;)
TimD
472
I was rushing around trying to squeeze the logging at half time last night.
I just pressed go on the 3 blocks and then start and began to drive.
The laptop was running out of battery quickly and slowing up.
Now i am more familiar with what i'm doing i'll have another go tonight!
Radek
70
Code:
Group C:	'002
TIME
STAMP	 /min	%	 ms	 g/s
How do you export VAG values to such nice layout ?
Radek
70
But only option I have in VAG is export to CSV file ( comma separated )
and it doesn't looks so cool in excel :\
Jonzy
open the csv file in notepad and copy the text into the reply box enclosed in
Code:
tags
